Eclipse Community Forumsthe declared package "" does not match the expected package - SOLVED
https://www.eclipse.org/forums/index.php/mv/msg/369033/900197/#msg_900197
I've been trying to learn Java with tutorial from youtube, but since i cant post link i can only sane that it is name "Java Video Tutorial" from user "derekbanas", but the problem I have with it is that when he started recording, he already had his eclipse set up and started project with file already in it.
Now everytime I try to do what he does, I get the error the declared package "" does not match the expected package.
This is what I do:
Start Eclipse, new workspace in Eclipse folder,E:\Eclipse\workspace File>New>Java Project enter>use default JRE (currently jre7),name "Test" press Finish
Expand Test>right click on src>New package>name package defaultPackage in source folder Test/src>Finish
Right click defaultPackage>New File>HelloWorld.java
Enter code>Ctrls+s to save BAM, declared package does not match the expected package.
What Am I doing wrong that I am getting the error?
Thanks for your time
SOLVED: Instead of creating new package, I just clicked on SRC and created new file, naming it HelloWorld and it created the default package by itself.]]>M M2012-08-05T09:14:56-00:00Re: =?UTF-8?B?dGhl77u/IGRlY2xhcmVkIHBhY2thZ2UgIiIgZG9lcyBub3QgbWE=?=
https://www.eclipse.org/forums/index.php/mv/msg/369033/900204/#msg_900204
> Hello,
> This is what I do:
> press Finish
> expected package.
The package statement at the top of your HelloWorld.java file has to
match the directory hierarchy from the src location on. You substitue /
for . in the package name to get the hierarchy.
A package com.test.myapp has to be in the directory hierarchy
com/test/myapp/]]>David Wegener2012-08-05T13:58:20-00:00
