Eclipse Community Forums[xcore] enum in switch statement
https://www.eclipse.org/forums/index.php/mv/msg/367794/896768/#msg_896768
defining a operation in xcore brings me to the point to have a switch statement using a enum
property. But i can't figure out how to code the case:
Example:
enum EditType
PROJECT_FILE = 0
DATABASE = 1
class A
EditType editType
op void doSomeThing(){
switch(editType){
case DATABASE: //getting an ERROR
case 1: //this is OK but not nice
How do I specify the specific switch case?
Martin]]>Martin Jacob2012-07-19T16:24:20-00:00Re: [xcore] enum in switch statement
https://www.eclipse.org/forums/index.php/mv/msg/367794/896849/#msg_896849
You use it like this:
switch(editType){
case EditType::PROJECT_FILE:
case EditType::DATABASE:
I.e., the Xbase syntax for referring to static fields uses "::" not
".". It would be nice if Xbase made the enumerator's visible without
qualification in the switch. Maybe you could open a bugzilla
enhancement against Xtext's Xbase. Please post the bugzilla number here.
On 19/07/2012 6:24 PM, Martin Jacob wrote:
> Hi
> statement using a enum property. But i can't figure out how to code
> the case:
> Example:
> enum EditType
> PROJECT_FILE = 0
> DATABASE = 1
> class A
> EditType editType
> switch(editType){
> Martin]]>Ed Merks2012-07-20T06:46:50-00:00Re: [xcore] enum in switch statement
https://www.eclipse.org/forums/index.php/mv/msg/367794/1096716/#msg_1096716
https://bugs.eclipse.org/bugs/show_bug.cgi?id=400096.]]>Miles Parker2013-08-28T19:27:34-00:00
