Eclipse Community Forums"Convert to a C/C++ project" missing
https://www.eclipse.org/forums/index.php/mv/msg/367431/895446/#msg_895446
following a tutorial, I am using eclipse juno for java developers, have downloaded all the cdt software, android sdk, ndk and cygwin.
now the tutorial says i should go project -> new -> "Convert to a C/C++ project" but that doesn't exist in my menu.
i have downloaded eclipse for c/c++ which ahs this functionality. but then, my project there is already a c/c++ project and all tutorials specify using eclipse for java with android and using the "Convert to a C/C++ project" function to make it a hybrid project.
could I be missing some software installation to get this functionality?
my core problem is that while i can make my android project talk to a native class, when i include second class, the header is included but the according c++ file is never fed to the compiler. i tried that with #error which worked fine in the header files but not in the c++ files.
I have tried the same c++ project in visual studio where it references the files fine so i can rule out wrong referencing in the code. I have also tried it with a very simple 2 class project and it is the same. the header file is ok but the cpp file is never compiled which means i can not use any functionality of those classes
i have a lot of these errors when compiling:
undefined reference to `foo::getBar()'
so i have actually two questions: first, how do i get "Convert to a C/C++ project" to show up and secondly, would that be the reason why my c++ files are not compiled or am I missing something else there?
any help is greatly appreciated as this is driving me crazy now...]]>mary ann tailor2012-07-13T00:46:57-00:00Re: "Convert to a C/C++ project" missing
https://www.eclipse.org/forums/index.php/mv/msg/367431/953216/#msg_953216
this.]]>Hendrick Prasdito2012-10-22T04:28:20-00:00Re: "Convert to a C/C++ project" missing
https://www.eclipse.org/forums/index.php/mv/msg/367431/1805604/#msg_1805604
https://mobilunity.com/blog/how-to-convert-applications-written-in-c-to-java/]]>Anastasia Stefanuk2019-04-18T14:42:57-00:00
