Eclipse Community ForumsRetrieve target folder during generation
https://www.eclipse.org/forums/index.php/mv/msg/367247/894754/#msg_894754
is there a way to retrieve the target folder during generation? With target folder I mean the root folder to which all files are generated, configured in the launch configuration.
I would like to use this to provide a warning to the user in case a file is generated to another location, such that he can manually remove it from the old location. Please note that both locations are determined at forehand.
Thanks!]]>Niels Brouwers2012-07-10T11:49:00-00:00Re: Retrieve target folder during generation
https://www.eclipse.org/forums/index.php/mv/msg/367247/894756/#msg_894756
Niels Brouwers2012-07-10T11:51:09-00:00
