Eclipse Community ForumsSimpleIDE compilation problem
https://www.eclipse.org/forums/index.php/mv/msg/366864/893487/#msg_893487
can someone advice me, which all plugins are necessary to compile and run SimpleIDE?
I checked-out everything which had simpleide in the name but I cannot compile it. Even Opening Application.e4xmi fails:
is it best to check out everything into plain new workspace?
thanks a lot. marek
org.eclipse.emf.ecore.resource.impl.ResourceSetImpl$1DiagnosticWrappedException: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/e4/demo/simpleide' not found. (platform:/resource/org.eclipse.e4.demo.simpleide/Application.e4xmi, 2, 526)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.handleDemandLoadException(ResourceSetImpl.java:319)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:278)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.getResource(ResourceSetImpl.java:406)
at org.eclipse.e4.tools.emf.ui.common.XMIModelResource.<init>(XMIModelResource.java:67)
at org.eclipse.e4.tools.emf.editor3x.XMIResourceFunction.compute(XMIResourceFunction.java:21)
at org.eclipse.e4.core.internal.contexts.ValueComputation.get(ValueComputation.java:60)
at org.eclipse.e4.core.internal.contexts.EclipseContext.internalGet(EclipseContext.java:221)
at org.eclipse.e4.core.internal.contexts.EclipseContext.internalGet(EclipseContext.java:230)
at org.eclipse.e4.core.internal.contexts.EclipseContext.get(EclipseContext.java:192)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier.fillArgs(ContextObjectSupplier.java:180)
at org.eclipse.e4.core.internal.contexts.ContextObjectSupplier.get(ContextObjectSupplier.java:164)
at org.eclipse.e4.core.internal.di.InjectorImpl.resolveArgs(InjectorImpl.java:426)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:311)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:240)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
at org.eclipse.e4.tools.compat.internal.PartHelper.creatComponent(PartHelper.java:76)
at org.eclipse.e4.tools.compat.parts.DIEditorPart.createPartControl(DIEditorPart.java:92)
at org.eclipse.e4.tools.emf.editor3x.E4WorkbenchModelEditor.createPartControl(E4WorkbenchModelEditor.java:43)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.createPartControl(CompatibilityPart.java:129)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityEditor.createPartControl(CompatibilityEditor.java:95)
at org.eclipse.ui.internal.e4.compatibility.CompatibilityPart.create(CompatibilityPart.java:300)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:857)
at org.eclipse.e4.core.internal.di.InjectorImpl.processAnnotated(InjectorImpl.java:837)
at org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:111)
at org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:318)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
at org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
at org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:889)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:623)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:725)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:696)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:690)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:675)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl$1.handleEvent(PartServiceImpl.java:90)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:57)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:418)
at org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:385)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:578)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.bringToTop(PartServiceImpl.java:314)
at org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:962)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:3071)
at org.eclipse.ui.internal.WorkbenchPage.access$21(WorkbenchPage.java:2996)
at org.eclipse.ui.internal.WorkbenchPage$8.run(WorkbenchPage.java:2978)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2974)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2933)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2924)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:655)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:614)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:360)
at org.eclipse.jdt.internal.ui.javaeditor.EditorUtility.openInEditor(EditorUtility.java:167)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:249)
at org.eclipse.jdt.ui.actions.OpenAction.run(OpenAction.java:228)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.dispatchRun(SelectionDispatchAction.java:275)
at org.eclipse.jdt.ui.actions.SelectionDispatchAction.run(SelectionDispatchAction.java:251)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerActionGroup.handleOpen(PackageExplorerActionGroup.java:376)
at org.eclipse.jdt.internal.ui.packageview.PackageExplorerPart$4.open(PackageExplorerPart.java:538)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
Caused by: org.eclipse.emf.ecore.xmi.PackageNotFoundException: Package with uri 'http://www.eclipse.org/e4/demo/simpleide' not found. (platform:/resource/org.eclipse.e4.demo.simpleide/Application.e4xmi, 2, 526)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getPackageForURI(XMLHandler.java:2585)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.getFactoryForPrefix(XMLHandler.java:2416)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createObjectByType(XMLHandler.java:1293)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.createTopObject(XMLHandler.java:1462)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.processElement(XMLHandler.java:1013)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.processElement(XMIHandler.java:77)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:995)
at org.eclipse.emf.ecore.xmi.impl.XMLHandler.startElement(XMLHandler.java:706)
at org.eclipse.emf.ecore.xmi.impl.XMIHandler.startElement(XMIHandler.java:163)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.dtd.XMLDTDValidator.startElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanStartElement(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$ContentDriver.scanRootElementHook(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl$FragmentContentDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl$PrologDriver.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentScannerImpl.next(Unknown Source)
at com.sun.org.apache.xerces.internal.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XML11Configuration.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.XMLParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.parsers.AbstractSAXParser.parse(Unknown Source)
at com.sun.org.apache.xerces.internal.jaxp.SAXParserImpl$JAXPSAXParser.parse(Unknown Source)
at javax.xml.parsers.SAXParser.parse(Unknown Source)
at org.eclipse.emf.ecore.xmi.impl.XMLLoadImpl.load(XMLLoadImpl.java:175)
at org.eclipse.emf.ecore.xmi.impl.XMLResourceImpl.doLoad(XMLResourceImpl.java:240)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1505)
at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1284)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoad(ResourceSetImpl.java:259)
at org.eclipse.emf.ecore.resource.impl.ResourceSetImpl.demandLoadHelper(ResourceSetImpl.java:274)
... 122 more
]]>Marek Jasovsky2012-07-04T10:41:31-00:00Re: SimpleIDE compilation problem
https://www.eclipse.org/forums/index.php/mv/msg/366864/893490/#msg_893490
I think having the e4-tools in your target platform might be useful
Am 04.07.2012 12:41, schrieb Marek Jasovsky:
> Hi
> run SimpleIDE?
> thanks a lot. marek
> 526)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> 526)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> Source)
> at
> at
> Source)
> at
> Source)
> at
> at
> at
> at
> at
> at
> ... 122 more
>]]>Oliver Koch2012-07-04T10:44:52-00:00Re: SimpleIDE compilation problem
https://www.eclipse.org/forums/index.php/mv/msg/366864/893491/#msg_893491
thanks for quick response.
org.eclipse.e4.tools is contained as project in my workspace. thought this should be enough.
I think, the org.eclipse.e4.demo.simpleide plugin fails to resolve
Am 04.07.2012 12:48, schrieb Marek Jasovsky:
> Hi
> Marek]]>Oliver Koch2012-07-04T10:58:05-00:00Re: SimpleIDE compilation problem
https://www.eclipse.org/forums/index.php/mv/msg/366864/893496/#msg_893496
trouble mght be, that tools.services package is in wrong version. required is 1.0.0 but I do not know, where to get it. downloaded version from CVS seems to have only 0.12.0 as version.
this error occurs exactly in the org.eclipse.e4.demo.simpleide plugin.
Marek]]>Marek Jasovsky2012-07-04T11:02:49-00:00Re: SimpleIDE compilation problem
https://www.eclipse.org/forums/index.php/mv/msg/366864/893498/#msg_893498
Am 04.07.2012 13:02, schrieb Marek Jasovsky:
> I do not understand either.
> Marek]]>Oliver Koch2012-07-04T11:06:55-00:00Re: SimpleIDE compilation problem
https://www.eclipse.org/forums/index.php/mv/msg/366864/893504/#msg_893504
now it compiles but still will not start.
Marek]]>Marek Jasovsky2012-07-04T11:29:26-00:00Re: SimpleIDE compilation problem
https://www.eclipse.org/forums/index.php/mv/msg/366864/893506/#msg_893506
any idea how to solve this?
Thanks in advance
Marek]]>Marek Jasovsky2012-07-04T11:36:48-00:00Re: SimpleIDE compilation problem
https://www.eclipse.org/forums/index.php/mv/msg/366864/893509/#msg_893509
for your architecture/platform and that they are included in your run
configuration.
Am 04.07.2012 13:36, schrieb Marek Jasovsky:
> Neither start through exported standalone app works. it seems, that in
> export, there is not the real swt.jar included, that's why it cannot
> find swt classes.
> Thanks in advance
> Marek]]>Oliver Koch2012-07-04T11:59:43-00:00Re: SimpleIDE compilation problem
https://www.eclipse.org/forums/index.php/mv/msg/366864/893511/#msg_893511
my target platform contains then, but how to include one particular jar, to run configuration, so that it is included in classpath / packaged when I export whole app? this am I struggling somehow. when I manually added it to artifacts.xml and config.ini, then I could start it, but only as standalone app. not from eclipse.
thanks a lot for your help so far
Marek
Oliver Koch wrote on Wed, 04 July 2012 07:59
You must make sure that your target platform contains the swt bundles
configuration.
> find swt classes.
> Thanks in advance
> Marek
]]>Marek Jasovsky2012-07-04T12:02:44-00:00Re: SimpleIDE compilation problem
https://www.eclipse.org/forums/index.php/mv/msg/366864/893512/#msg_893512
plug-ins tab).
you could click the validate button in the product file, too
Am 04.07.2012 14:02, schrieb Marek Jasovsky:
> Hi
> Marek
>> configuration.
>> > find swt classes.
>> > Thanks in advance
>> > Marek
>]]>Oliver Koch2012-07-04T12:06:56-00:00Re: SimpleIDE compilation problem
https://www.eclipse.org/forums/index.php/mv/msg/366864/893522/#msg_893522
everything works.
where should I report bugs within SimpleIDE? (Menu and Toolbar appearing multiple times, in case I start it within same workspace)
