Eclipse Community ForumsNo output in eclipse console
https://www.eclipse.org/forums/index.php/mv/msg/365232/890216/#msg_890216
i installed the latest version of eclipse on my computer and used a little bit of java code.
No errors displayed. The only problem is when i press the run button there is no output in the eclipse console. "Allocate console" is activated.
I successfully compiled my .java-file with the cmd and got it to run with java. Everything works perfect but not in eclipse.
Does anybody know an answer? ]]>julius wetzk2012-06-21T13:35:28-00:00Re: No output in eclipse console
https://www.eclipse.org/forums/index.php/mv/msg/365232/890217/#msg_890217
Make sure that you create a Java project and that your Java files are in
a source folder of that project.
Dani
> activated.
> Does anybody know an answer?]]>Dani Megert2012-06-21T13:42:37-00:00Re: No output in eclipse console
https://www.eclipse.org/forums/index.php/mv/msg/365232/890224/#msg_890224
i use a java project and the java-file is in the src folder.
Any other solution?
]]>julius wetzk2012-06-21T14:04:32-00:00Re: No output in eclipse console
https://www.eclipse.org/forums/index.php/mv/msg/365232/890229/#msg_890229
> Hi Danny,
> Any other solution?
You don't have auto-build on and forgot to build?
Dani]]>Dani Megert2012-06-21T14:16:23-00:00Re: No output in eclipse console
https://www.eclipse.org/forums/index.php/mv/msg/365232/890230/#msg_890230
Sorry, but im totally new to this.]]>julius wetzk2012-06-21T14:20:46-00:00Re: No output in eclipse console
https://www.eclipse.org/forums/index.php/mv/msg/365232/890233/#msg_890233
> Dont know what you mean by auto-build. Is this a function in eclipse?
Help > Welcome. Then go through the 'Create a Hello World application'
tutorial
Dani]]>Dani Megert2012-06-21T14:23:00-00:00Re: No output in eclipse console
https://www.eclipse.org/forums/index.php/mv/msg/365232/890237/#msg_890237
As i said i got it running with the command line so my java code is correct.
The function "build automatically" was and is activated.
I changed nothing in eclipse. Is there any other thing i can do? I really need this to work.
]]>julius wetzk2012-06-21T14:41:52-00:00Re: No output in eclipse console
https://www.eclipse.org/forums/index.php/mv/msg/365232/890239/#msg_890239
> I did the tutorial but that didnt help.
> correct.
What happens when you drill down to your .java file in the Project or
Package Explorer view, right-click it, and choose Run As -> Java
Application?]]>Russell Bateman2012-06-21T14:52:05-00:00Re: No output in eclipse console
https://www.eclipse.org/forums/index.php/mv/msg/365232/890242/#msg_890242
all the same.
]]>julius wetzk2012-06-21T15:06:24-00:00Re: No output in eclipse console
https://www.eclipse.org/forums/index.php/mv/msg/365232/892180/#msg_892180
Followed the tutorial, didnt throw errors.
I don't know which step was implicit in the tutorial.]]>Marcel Baalbaki2012-06-27T10:19:02-00:00
