Eclipse Community ForumsGdb Pretty Print on Windows
https://www.eclipse.org/forums/index.php/mv/msg/361469/885388/#msg_885388
I can't understand why this feature is so difficult to install - Visual Studio works out of the box. I'm using gcc 4.7 with MinGW and I've tried lots of versions of Eclipse, lots of versions of gdb, but to no avail.
Is there a definitive version of the {MinGW, CDT, Eclipse, Gdb} set that is known to work. The Gdb is particularly annoying, because the latest versions are supposed to support Python scripting, but don't and building from source keeps failing (not to mention being very complicated).
CDT is a brilliant product, but no STL debugging is a major drawback.
]]>Chris Seddon2012-06-12T22:47:00-00:00Re: Gdb Pretty Print on Windows
https://www.eclipse.org/forums/index.php/mv/msg/361469/885529/#msg_885529
http://sourceforge.net/projects/mingw/files/MinGW/Extension/gdb/GDB-7.4/
Additionally, you will need to install python 2.7.x available via python.org
