Eclipse Community ForumsNo way to run the MAT
https://www.eclipse.org/forums/index.php/mv/msg/360920/884554/#msg_884554
My system:
Linux-amd64
Ram: 4Gb
Running: Just the MAT stand-alone and a couple of xterms.
Free memory before starting MAT: 3Gb
MAT run arguments (MemoryAnalyzer.ini):
-vmargs
-Xmx2g
-XX:-UseGCOverheadLimit
I began trying from Eclipse but, as it always failed at 25% while opening a *.hprof dump, I moved to stand alone version and same result.
Failure Log Message: See Picture Attached.
]]>Jon Locke2012-06-11T10:30:12-00:00Re: No way to run the MAT [SOLVED]
https://www.eclipse.org/forums/index.php/mv/msg/360920/885016/#msg_885016
Never mind, with a clearer idea in mind, I just limited the -Xmx parameter to force the dump to be smaller .....as simple as that.
Now I'm at last able to test the MAT.]]>Jon Locke2012-06-12T09:18:59-00:00
