Eclipse Community ForumsATL collection and Iteration error?
https://www.eclipse.org/forums/index.php/mv/msg/354582/875807/#msg_875807
module tpf3;
create OUT : target from IN : source;
rule Rule_DeviceT{
from
a: source!DeviceItem,
c:source!ModuleItem
to
p:target!Device(
name <- a.Name,
Module<-a.ModuleList.ModuleItem->collect(e|thisModule.Rule_ModuleT(e))
lazy rule Rule_ModuleT{
from
b:source!ModuleItem
to
d:target!Module(
name <- b.Name,
s7ModuleReference <- b.ModuleReference
Problem: How to remove the data repetition in output file? This is because something wrong with "Module<-a.ModuleList.ModuleItem->collect(e|thisModule.Rule_ModuleT(e))" in the ATL file. Can someone support me to solve this issue?
Thanks in advance.
Kosala]]>Kosala Yapa2012-05-23T10:54:49-00:00Re: ATL collection and Iteration error?
https://www.eclipse.org/forums/index.php/mv/msg/354582/875821/#msg_875821
You have posted this to the ATL newsgroup. Please refrain from spamming
others.
Ed Willink
On 23/05/2012 11:54, Kosala Yapa wrote:
> Hi there,
> Input file:
> <?xml version="1.0" encoding="ISO-8859-1"?>
> <xmi:XMI xmi:version="2.0" xmlns:xmi=".../XMI" xmlns="source">
> <DeviceList>
> <DeviceItem Name="PSSuniversal22222" DeviceCommReference=
> "001417C3-00000003-001417B3-00000002-00112001-0000013A"
> DeviceReference="{7F6AC5F1-E8E0-49E5-ABA1-26E4A6A74175}{001417C3-00000003-001417B3-00000002-00112001-00000107}{SD_example1}">
> <ModuleList>
> <ModuleItem Name="PSSu E F PS (PROFIsafe)"
> IsSelected="false"
> ModuleReference="{9A856DAC-1D0A-46F7-B69F-40E2DC6511DD}{001417C5-0000002F-001417C3-0000002A-00112001-00000107}{SD_example1}">
> </ModuleItem>
> <ModuleItem Name="PSSuES4DO0.5_1"
> ModuleReference="CFAF3ED5-37E4-476B-AE64-94FDD6429D1E}{001417C5-00000009-001417C3-00000003-00112001-00000107">
> </ModuleItem>
> <ModuleItem Name="PSSuES4DO0.5_2"
> ModuleReference="CFAF3ED5-37E4-476B-AE64-94FDD6429D1E}{001417C5-00000009-001417C3-00000003-00112001-00000108">
> </ModuleItem>
> </ModuleList>
> </DeviceItem>
> </DeviceList>
> </xmi:XMI>
> Output file:
> <xmi:XMI xmi:version="2.0" xmlns:xmi=".../XMI" xmlns="target">
> <Device name="PSSuniversal22222">
> <Module name="PSSu E F PS (PROFIsafe)"
> s7ModuleReference="{9A856DAC-1D0A-46F7-B69F-40E2DC6511DD}{001417C5-0000002F-001417C3-0000002A-00112001-00000107}{SD_example1}"/>
> <Module name="PSSuES4DO0.5_1"
> s7ModuleReference="CFAF3ED5-37E4-476B-AE64-94FDD6429D1E}{001417C5-00000009-001417C3-00000003-00112001-00000107"/>
> <Module name="PSSuES4DO0.5_2"
> s7ModuleReference="CFAF3ED5-37E4-476B-AE64-94FDD6429D1E}{001417C5-00000009-001417C3-00000003-00112001-00000108"/>
> </Device>
> </Device>
> </Device>
> </xmi:XMI>
> ATL program:
> -- @path source=file:/C:/.../source.ecore
> -- @path target=file:/C:/.../target.ecore
> module tpf3;
> rule Rule_DeviceT{
> from
> c:source!ModuleItem
> to
> p:target!Device(
> name <- a.Name,
> from
> b:source!ModuleItem
> to
> d:target!Module(
> name <- b.Name,
> Thanks in advance.
> Kosala]]>Ed Willink2012-05-23T11:35:55-00:00
