Eclipse Community ForumsSVN: Check out as a folder into existing project folder
https://www.eclipse.org/forums/index.php/mv/msg/351408/871193/#msg_871193
I have created a PHP-Project like this:
The Problem:
For example I need to check out PluginA to this folder: "/SomeProjectA/Plugins/" , but NOT to Project --> "SomeProjectA"
I'm using subversive plugin for eclipse...
But if I choose the Option "Check out as a folder into existing project" in SVN Check Out wizard, eclipse show me this warning:
Destination project is detached from the source control. So please take into consideration that the plug-in won't provide any SVN actions for these resources.
I'm able to see the out checked files, but eclipse dosen't support source control for the folder "PluginA".
What do I wrong? Can someone help me?]]>Arash Missing name2012-05-11T11:34:03-00:00Re: SVN: Check out as a folder into existing project folder
https://www.eclipse.org/forums/index.php/mv/msg/351408/886542/#msg_886542
use the svn:external property instead. Please check out SVN documentation.
