Eclipse Community ForumsEclipse Plug-in Project vs. Plug-in in Target Platform
https://www.eclipse.org/forums/index.php/mv/msg/34441/111616/#msg_111616
Originally posted by: chopkins.cra.com
I have a plug-in that has been developed by an external client. I use the
plug-in as a project within my workspace and all my plug-ins that depend on
it are working fine. However, if I try to export that plug-in and include it
as part of my defined Target Platform (so I don't have to have it as a
project in my workspace) then weird things happen. This is related to my
other post about mission constraints. Here's what happens:
* When I include the plug-in as a project in my workspace, everything
compiles and runs fine
* I then try the following:
1. Export that plug-in (exporting it as a directory and not a .jar as it
contains embedded jar files that Eclipse doesn't like)
2. close the project
3. Add the exported plug-in to my defined Target Platform
* This results in my plug-in projects being able to compile but when I try
to run I get a Validation Error that says:
Missing Constraint: Import-Package: com.draper.jaguar.datacore; version =
"0.0.0"
Why can my plugin projects see those packages at compile time but not run
time? Is there some configuration difference that I'm missing?
Chris]]>2008-06-09T19:48:08-00:00Re: Eclipse Plug-in Project vs. Plug-in in Target Platform
https://www.eclipse.org/forums/index.php/mv/msg/34441/111624/#msg_111624
Originally posted by: ekkehard.gentz-software.de
chris,
seems that your plug-in has an
in the MANIFEST.MF
so there must be another bundle exporting this package to make your bundle
happy
there's always a difference between compile-time and run-time ;-)
the compiler is satisfied if all needed classes are in project classpath
at compile-time
if you run the bundle from your target platform the bundle-classpath has
to find all and your Import-Package says that there must be a package but
it wasn't found.
what if you install your bundle from console and test with diag ?
if you dont need the package always, then you can make it optional
ekke
Christopher Hopkins wrote:
.... but when I try
> "0.0.0"
