Eclipse Community Forums[agr] failing to run in standard mode
https://www.eclipse.org/forums/index.php/mv/msg/34270/111100/#msg_111100
Originally posted by: bmf1972.fastmail.fm
Hi all,
I am trying to build automated GUI tests for Eclipse plugin.
So far I have tried it on Eclipse 3.2 with no success, and now after
upgrading to Eclipse 3.3 I hoped to see auto GUI tests running :-(
After I have installed Eclipse 3.3 I have installed TPTP 4.4 through the
Europa update site.
I am able to run the test in "quick mode" (it also worked in Eclipse
3.2), but when I am trying to run in "standard mode", the launcher just
gets stuck with 31%.
I have tried to launch with firewall completely disabled -- still with
same result :-(
When looking at the processes I see that the eclipse.exe process is
taking 50% CPU time (on my dual-core machine it means 100% of one
processor). The launched ACServer.exe and TPTPProcessController.exe are
idle.
Here is servicelog.log file:
(NOTE: I don't know what is the "D:\cygwin\..." path -- I even do not
have a D: fixed drive)
Please help,
Adrian.]]>2007-09-01T10:15:55-00:00Re: [agr] failing to run in standard mode
https://www.eclipse.org/forums/index.php/mv/msg/34270/111194/#msg_111194
Apparently the ACServer configuration file (serviceconfig.xml) is not
generated successfully if TPTP is installed in an extension plugin
directory. I have installed TPTP and its dependencies in my main
extension directory and that solved the problem above (though there are
others... On my WinXP machine, I have to run the ACServer standalone,
otherwise it Eclipse crashes when trying to configure it) .
Adrian Herscu wrote:
> Hi all,
> Europa update site.
> I am following the instructions here
> http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-4-0.html#2.2.3
> same result :-(
> idle.
> <CommonBaseEvent creationTime="2007-09-01T09:57:26.437000Z"
> globalInstanceId="A89EC9DCD4A047F9A7A900B2C923A99E" msg="Received
> command for unrecognized interface: iid=org.eclipse.tptp.eventProvider,
> cmd=listenerAccepted" severity="50" version="1.0.1">
> <sourceComponentId component="AgentController"
> componentIdType="TPTPComponent"
> executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.0\TPTP-4.4.0-200706140100C\agn tctrl\src\transport\TPTPClientCompTL\Connect2AC.c,
> line 2238" instanceId="1004" location="manager" locationType="IPV4"
> processId="2936" subComponent="Client Compatibility TL" threadId="2848"
> componentType="Eclipse_TPTP"/>
> <situation categoryName="ReportSituation">
> <situationType
> xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
> xsi:type="ReportSituation" reasoningScope="INTERNAL" reportCategory="LOG"/>
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2007-09-01T09:57:26.828000Z"
> globalInstanceId="A09A4C2A39564F399C1A9595CBBBA64A" msg="Received
> PUT_FILE command from client" severity="10" version="1.0.1">
> executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.0\TPTP-4.4.0-200706140100C\agn tctrl\src\transport\TPTPClientCompTL\RACmdHandlers.c,
> line 877" instanceId="1004" location="manager" locationType="IPV4"
> processId="2936" subComponent="Client Compatibility TL" threadId="2168"
> <situationType
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2007-09-01T09:57:26.843000Z"
> globalInstanceId="AB26E70285E14243A6CDD882F389802A" msg="Received
> <situationType
> </situation>
> </CommonBaseEvent>
> <CommonBaseEvent creationTime="2007-09-01T09:57:26.937000Z"
> globalInstanceId="A9F192E8C54A477E9042B35A04809E5E" msg="File server
> started listening on port 10005" severity="10" version="1.0.1">
> executionEnvironment=" D:\cygwin\home\build\TPTP\4.4.0\TPTP-4.4.0-200706140100C\agn tctrl\src\transport\TPTPClientCompTL\fileServer.c,
> line 177" instanceId="1004" location="manager" locationType="IPV4"
> processId="2936" subComponent="Client Compatibility TL" threadId="3348"
> <situationType
> </situation>
> </CommonBaseEvent>
> The serviceconfig.xml:
> <AgentControllerConfiguration>
> <AgentControllerEnvironment configuration="default">
> <Variable name="JAVA_PATH" position="replace" value="C:\Program
> Files\Java\jdk1.6.0_01\jre\bin\java.exe"/>
> <Variable name="RASERVER_HOME" position="replace"
> value=" C:\documents\pm\eclipse-3.3.plugins\eclipse\plugins\org.ecli pse.tptp.platform.ac.win_ia32_4.4.0.v200706020100\agent_cont roller "/>
> <Variable name="TPTP_AC_HOME" position="replace"
> value="%RASERVER_HOME%"/>
> <Variable name="PLUGINS_HOME" position="replace"
> value="C:\documents\pm\eclipse-3.3.plugins\eclipse\plugins"/ >
> <Variable name="PATH" position="prepend"
> value="%RASERVER_HOME%\bin"/>
> <Variable name="SYS_TEMP_DIR" position="replace" value="%TEMP%"/>
> <Variable name="LOCAL_AGENT_TEMP_DIR" position="replace"
> value="%SYS_TEMP_DIR%"/>
> <Variable name="CLASSPATH_ORG_APACHE_COMMONS_LOGGING"
> position="append"
> value=" C:\documents\pm\eclipse-3.3.plugins\eclipse\plugins\org.apac he.commons.logging_1.0.4.v200706111724.jar "/>
> <Variable name="CLASSPATH_ORG_ECLIPSE_CORE_COMMANDS"
> position="append" value="null"/>
> <Variable name="CLASSPATH_ORG_ECLIPSE_CORE_RUNTIME"
> <Variable name="CLASSPATH_ORG_ECLIPSE_EQUINOX_COMMON"
> <Variable name="CLASSPATH_ORG_ECLIPSE_OSGI" position="append"
> value="null"/>
> <Variable name="CLASSPATH_ORG_ECLIPSE_EMF_COMMON"
> position="append"
> value=" C:\documents\pm\eclipse-3.3.plugins\eclipse\plugins\org.ecli pse.emf.common_2.3.0.v200706262000.jar "/>
> <Variable name="CLASSPATH_ORG_ECLIPSE_EMF_ECORE"
> position="append"
> value=" C:\documents\pm\eclipse-3.3.plugins\eclipse\plugins\org.ecli pse.emf.ecore_2.3.0.v200706262000.jar "/>
> <Variable name="CLASSPATH_ORG_ECLIPSE_EMF_ECORE_XMI"
> position="append"
> value=" C:\documents\pm\eclipse-3.3.plugins\eclipse\plugins\org.ecli pse.emf.ecore.xmi_2.3.0.v200706262000.jar "/>
> <Variable name="CLASSPATH_ORG_ECLIPSE_JFACE" position="append"
> value="null"/>
> <Variable name="CLASSPATH_ORG_ECLIPSE_SWT" position="append"
> value="null"/>
> <Variable name="CLASSPATH_ORG_ECLIPSE_TPTP_PLATFORM_MODELS"
> position="append"
> value=" C:\documents\pm\eclipse-3.3.plugins\eclipse\plugins\org.ecli pse.tptp.platform.models_4.3.0.v200706132116\fastxpath.jar;C :\documents\pm\eclipse-3.3.plugins\eclipse\plugins\org.eclip se.tptp.platform.models_4.3.0.v200706132116\tptp-models.jar "/>
> <Variable name="CLASSPATH_ORG_JUNIT" position="append"
> value="null"/>
> <Variable name="CLASSPATH_COM_IBM_ICU" position="append"
> value="null"/>
> <Variable name="CLASSPATH_ORG_APACHE_JAKARTA_COMMONS_LOGGING"
> position="append" value="%CLASSPATH_ORG_APACHE_COMMONS_LOGGING%"/>
> <Variable name="CLASSPATH" position="append" value="null"/>
> </AgentControllerEnvironment>
> <ApplicationAliases>
> <Application configuration="default" executable="java.exe"
> location="%SYS_TEMP_DIR%" path="%JAVA_PATH%">
> value="%CLASSPATH_ORG_ECLIPSE_EQUINOX_COMMON%"/>
> </Application>
> </ApplicationAliases>
> <Plugin path="%PLUGINS_HOME%"/>
> <Agent path="%TPTP_AC_HOME%\agents"/>
> <Logging directory="%TPTP_AC_HOME%\config" format="CBE"
> level="INFORMATION"/>
> <ProcessController>%TPTP_AC_HOME%\bin\tptpProcessController.exe </ProcessController>
> <Connection name="Dev">
> <TransportLayer loadlib="socketTL" type="TPTP_SOCKET">
> <Configuration>
> <Port>10006</Port>
> </Configuration>
> <CommandExtractor>tptpCmdExtr</CommandExtractor>
> </TransportLayer>
> <TransportLayer loadlib="namedPipeTL" type="TPTP_LOG">
> <Configuration>
> <PipeName>acmasterlog</PipeName>
> </Configuration>
> </TransportLayer>
> <TransportLayer loadlib="namedPipeTL" type="TPTP_NAMEDPIPE">
> <Configuration>
> <PipeName>acmaster</PipeName>
> </Configuration>
> </TransportLayer>
> <TransportLayer loadlib="sharedMemTL" type="TPTP_SHAREDMEM">
> <Configuration>
> <MemName>acbuffer</MemName>
> </Configuration>
> </TransportLayer>
> <TransportLayer loadlib="tptpCCTL" type="TPTP_CCTL">
> <Configuration>
> <Port>10002</Port>
> <SecuredPort>10003</SecuredPort>
> <FilePort>10005</FilePort>
> <IsDataMultiplexed>false</IsDataMultiplexed>
> <ProcessPolling>true</ProcessPolling>
> <Jvm>C:\Program
> Files\Java\jdk1.6.0_01\jre\bin\server\jvm.dll</Jvm>
> <Version>4.4.0</Version>
> <SecurityEnabled>false</SecurityEnabled>
> <Hosts configuration="default">
> <Allow host="LOCAL"/>
> </Hosts>
> </Configuration>
> </TransportLayer>
> <TransportLayer loadlib="tptpACTL" type="TPTP_ACTL">
> <Configuration/>
> </TransportLayer>
> </Connection>
> <PeerConnectionTransport>TPTP_CCTL</PeerConnectionTransport >
> </AgentControllerConfiguration>
> Please help,
> Adrian.]]>2007-09-03T14:55:26-00:00Re: [agr] failing to run in standard mode
https://www.eclipse.org/forums/index.php/mv/msg/34270/112656/#msg_112656
The malformed serviceconfig.xml file appears to be a defect. Can you
open a bugzilla
( https://bugs.eclipse.org/bugs/enter_bug.cgi?product=TPTP%20A gent%20Controller)
under the config component (note in the defect that this is the IAC)?
Can you consistently reproduce the crash on XP? If so, please open
another defect for the crash.
Paul
"Adrian Herscu" <bmf1972@fastmail.fm> wrote in message
news:fbh79a$344$1@build.eclipse.org...
> directory. I have installed TPTP and its dependencies in my main extension
> directory and that solved the problem above (though there are others... On
> my WinXP machine, I have to run the ACServer standalone, otherwise it
>> Hi all,
>> Europa update site.
>> http://www.eclipse.org/tptp/test/documents/userguides/Intro- Auto-GUI-4-4-0.html#2.2.3 I
>> am able to run the test in "quick mode" (it also worked in Eclipse 3.2),
>> but when I am trying to run in "standard mode", the launcher just gets
>> stuck with 31%.
>> same result :-(
>> idle.
>> globalInstanceId="A89EC9DCD4A047F9A7A900B2C923A99E" msg="Received command
>> <situationType
>> </situation>
>> </CommonBaseEvent>
>> <situationType
>> </situation>
>> </CommonBaseEvent>
>> <situationType
>> </situation>
>> </CommonBaseEvent>
>> <situationType
>> </situation>
>> </CommonBaseEvent>
>> <?xml version="1.0" encoding="UTF-8"?>
>> position="append"
>> <Variable name="CLASSPATH_ORG_ECLIPSE_CORE_COMMANDS" position="append"
>> value="null"/>
>> value="null"/>
>> position="append"
>> <Variable name="CLASSPATH_ORG_ECLIPSE_EMF_ECORE" position="append"
>> <Variable name="CLASSPATH_ORG_ECLIPSE_EMF_ECORE_XMI" position="append"
>> value="null"/>
>> value="null"/>
>> position="append"
>> <Variable name="CLASSPATH_ORG_JUNIT" position="append" value="null"/>
>> value="null"/>
>> </Application>
>> <Configuration>
>> <Port>10006</Port>
>> </Configuration>
>> </TransportLayer>
>> <Configuration>
>> </Configuration>
>> </TransportLayer>
>> <Configuration>
>> </Configuration>
>> </TransportLayer>
>> <Configuration>
>> </Configuration>
>> </TransportLayer>
>> <Configuration>
>> <Port>10002</Port>
>> <Jvm>C:\Program
>> </Hosts>
>> </Configuration>
>> </TransportLayer>
>> <Configuration/>
>> </TransportLayer>
>> </Connection>
>> Please help,
>> Adrian.]]>Paul Slauenwhite2007-09-19T12:04:41-00:00Re: [agr] failing to run in standard mode
https://www.eclipse.org/forums/index.php/mv/msg/34270/112670/#msg_112670
I see by your other post that this has been resolved. Also, using a new
workspace will resolve this issue.
The D:\cygwin\..." path is a hard coded path that will be removed under
defect:
