Eclipse Community Forumsautagent blocking scripted execution by leaving console stream open
https://www.eclipse.org/forums/index.php/mv/msg/317793/830454/#msg_830454
Our thirdparty testagent stops the testprocess after starting the eclipse
application using autrun, blocking further execution, unable to continue to the
actual testrunner call.
This is caused by the autrun application, which apparently keeps at least one
output stream to console open.
We tried several options using start options and commandline arguments to
control all output streams.
Finally a wrapper application, which completely disconnects the autrun from
console, did the job.
Obviously this is not the desired solution for a couple of reasons.
The problem is reproducable, use the following command to start autrun:
"start /b autrun.exe [options/arguments...]"
which returns to new prompt. Now use "exit" to leave console.
As you see it stays open...
piping stdout and stderror to files or null does not help]]>Harald Menke2012-03-27T16:52:49-00:00Re: autagent blocking scripted execution by leaving console stream open
https://www.eclipse.org/forums/index.php/mv/msg/317793/830526/#msg_830526
here.]]>Alexandra Schladebeck2012-03-27T18:50:47-00:00
