Eclipse Community ForumsException when doing a Save All
https://www.eclipse.org/forums/index.php/mv/msg/305989/816297/#msg_816297
I am getting this stacktrace when I edit two model files, lets call them d1.q and d2.q, and change a list of root children in my really simple grammmer (A hierarchical model of Entities that can contain other Entities. Only attribute is an EString name). Both files are based on the same grammer, as the extension also indicates. When I change both files and press "Save All" i get the exception belov every time. Saving them one by one works fine. The cause has been located in the IGenerator Xtend implementation and is most likely a concurrency issue.
Any ideas to what is wrong?
Henrik Wivel
!ENTRY org.apache.log4j 4 0 2012-03-06 10:20:37.361
!MESSAGE org.eclipse.xtext.builder.impl.XtextBuilder - org.eclipse.core.internal.resources.ResourceException: Marker id 1503 not found.
!STACK 0
org.eclipse.emf.common.util.WrappedException: org.eclipse.core.internal.resources.ResourceException: Marker id 1503 not found.
at org.eclipse.xtext.util.Exceptions.throwUncheckedException(Exceptions.java:23)
at org.eclipse.xtext.builder.DerivedResourceMarkers$1.apply(DerivedResourceMarkers.java:131)
at org.eclipse.xtext.builder.DerivedResourceMarkers$1.apply(DerivedResourceMarkers.java:1)
at com.google.common.collect.Iterators$7.computeNext(Iterators.java:645)
at com.google.common.collect.AbstractIterator.tryToComputeNext(AbstractIterator.java:141)
at com.google.common.collect.AbstractIterator.hasNext(AbstractIterator.java:136)
at org.eclipse.xtext.builder.BuilderParticipant.build(BuilderParticipant.java:159)
at org.eclipse.xtext.builder.impl.RegistryBuilderParticipant.build(RegistryBuilderParticipant.java:60)
at org.eclipse.xtext.builder.impl.XtextBuilder.doBuild(XtextBuilder.java:160)
at org.eclipse.xtext.builder.impl.XtextBuilder.incrementalBuild(XtextBuilder.java:141)
at org.eclipse.xtext.builder.impl.XtextBuilder.build(XtextBuilder.java:91)
at org.eclipse.core.internal.events.BuildManager$2.run(BuildManager.java:728)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:199)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:239)
at org.eclipse.core.internal.events.BuildManager$1.run(BuildManager.java:292)
at org.eclipse.core.internal.events.BuildManager.basicBuild(BuildManager.java:295)
at org.eclipse.core.internal.events.BuildManager.basicBuildLoop(BuildManager.java:351)
at org.eclipse.core.internal.events.BuildManager.build(BuildManager.java:374)
at org.eclipse.core.internal.events.AutoBuildJob.doBuild(AutoBuildJob.java:143)
at org.eclipse.core.internal.events.AutoBuildJob.run(AutoBuildJob.java:241)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:54)
Caused by: org.eclipse.core.internal.resources.ResourceException: Marker id 1503 not found.
at org.eclipse.core.internal.resources.Marker.checkInfo(Marker.java:57)
at org.eclipse.core.internal.resources.Marker.getAttribute(Marker.java:98)
at org.eclipse.xtext.builder.DerivedResourceMarkers$1.apply(DerivedResourceMarkers.java:127)
... 21 more
]]>Henrik Wivel2012-03-08T17:08:36-00:00Re: Exception when doing a Save All
https://www.eclipse.org/forums/index.php/mv/msg/305989/816455/#msg_816455
I assume this was already fixed for 2.3
Did you find the stacktrace in the log or did you see an error dialog in
Eclipse?
Sebastian
Am 08.03.12 18:08, schrieb Henrik Wivel:
> Hi
> Regards
> Henrik Wivel
> not found.
> !STACK 0
> not found.
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> id 1503 not found.
> at
> ... 21 more
>]]>Sebastian Zarnekow2012-03-08T21:52:32-00:00Re: Exception when doing a Save All
https://www.eclipse.org/forums/index.php/mv/msg/305989/819005/#msg_819005
I am on Xtext 2.3 and the error showed up in the Console window.
