Eclipse Community ForumsAbout SCA Tools question
https://www.eclipse.org/forums/index.php/mv/msg/3001/8844/#msg_8844
When I using Eclipse3.5RC2 to do SCA Project,but it give me a problem.
by the way, when I design that SCA Diagram, I have no any error include
xxxx.composite_diagram file and Java source and xxxx.composite file.
When I run that project, the error message is........
2009/6/6 €W€È 02:20:26 org.apache.tuscany.sca.node.impl.NodeImpl <init>
žê°T: Creating node: Restaurant.composite
Exception in thread "main" org.osoa.sca.ServiceRuntimeException:
java.lang.IllegalArgumentException: Composite not found:
at org.apache.tuscany.sca.node.impl.NodeImpl.<init>(NodeImpl.java:171)
at
org.apache.tuscany.sca.node.impl.NodeFactoryImpl.createSCANo deFromClassLoader(NodeFactoryImpl.java:37)
at
org.apache.tuscany.sca.host.embedded.impl.DefaultSCADomain.i nit(DefaultSCADomain.java:175)
at
org.apache.tuscany.sca.host.embedded.impl.DefaultSCADomain.<init >(DefaultSCADomain.java:97)
at
org.apache.tuscany.sca.host.embedded.SCADomain.createNewInst ance(SCADomain.java:182)
at
org.apache.tuscany.sca.host.embedded.SCADomain.newInstance(S CADomain.java:63)
at test.Client.main(Client.java:11)
Caused by: java.lang.IllegalArgumentException: Composite not found:
at
org.apache.tuscany.sca.node.impl.NodeImpl.findNodeConfigurat ion(NodeImpl.java:197)
at org.apache.tuscany.sca.node.impl.NodeImpl.<init>(NodeImpl.java:166)
... 6 more]]>KevinWang2009-06-05T18:21:51-00:00Re: About SCA Tools question
https://www.eclipse.org/forums/index.php/mv/msg/3001/575268/#msg_575268
The composite file isn't in your classpath. Try to add the location of
your assembly file in the classpath.
Stephane Drapeau
Obeo
KevinWang a écrit :
> Hello : When I using Eclipse3.5RC2 to do SCA Project,but it give me a
> problem.
> at
> at
> at
> at
> at
> at
> ... 6 more
>]]>Stephane Drapeau2009-06-08T09:33:55-00:00Re: About SCA Tools question
https://www.eclipse.org/forums/index.php/mv/msg/3001/8889/#msg_8889
Stephane Drapeau
Obeo
> problem.
> at
> at
> at
> at
> at
> at
> ... 6 more
