Eclipse Community ForumsLatest IDE snapshot build?
https://www.eclipse.org/forums/index.php/mv/msg/287719/793861/#msg_793861
At the moment, the latest snapshot on download.eclipse.org/virgo/snapshot/IDE is 1.0.0.201110312003-SNAPSHOT, which seems to be quite old for a snapshot repository...
Andrew]]>Andrew Rootmann2012-02-08T17:15:48-00:00Re: Latest IDE snapshot build?
https://www.eclipse.org/forums/index.php/mv/msg/287719/793871/#msg_793871
https://hudson.eclipse.org/hudson/job/virgo.ide.snapshot/lastSuccessfulBuild/artifact/org.eclipse.virgo.ide.site/target/site/
(Seriously, please do *not* use this site as a regular update site as it is not designed as a download site and uses up limited Hudson resources, but if you're engaged in active testing or contributions it's worth looking there. In any case, the bug was just fixed and it looks like Hudson is going down for a bit, so it isn't available at the moment.)]]>Miles Parker2012-02-08T17:29:45-00:00Re: Latest IDE snapshot build?
https://www.eclipse.org/forums/index.php/mv/msg/287719/794185/#msg_794185
However, the new build appears to have some dependencies (see below) on some Libra bundles that are not yet available from their update site. I tried both Eclipse 3.7.1 and 3.7.2. Any suggestions?
Thanks a lot!
Andrew
Cannot complete the install because one or more required items could not be found.
Software being installed: Eclipse Virgo Tools 1.0.0.201202082045-SNAPSHOT (org.eclipse.virgo.ide.feature.feature.group 1.0.0.201202082045-SNAPSHOT)
Missing requirement: Eclipse Virgo IDE (Server UI) 1.0.0.201202082045-SNAPSHOT (org.eclipse.virgo.ide.runtime.ui 1.0.0.201202082045-SNAPSHOT) requires 'package org.eclipse.libra.framework.editor.core [0.1.0,2.0.0)' but it could not be found
Cannot satisfy dependency:
From: Eclipse Virgo Tools 1.0.0.201202082045-SNAPSHOT (org.eclipse.virgo.ide.feature.feature.group 1.0.0.201202082045-SNAPSHOT)
To: org.eclipse.virgo.ide.runtime.ui [1.0.0.201202082045-SNAPSHOT]]]>Andrew Rootmann2012-02-09T01:56:02-00:00Re: Latest IDE snapshot build?
https://www.eclipse.org/forums/index.php/mv/msg/287719/794188/#msg_794188
Try: http://download.eclipse.org/libra/milestones/ That's where we're consuming them from. By the way, when it comes to dependencies, an "easy" way to find these is to look at our pom, here:
