Eclipse Community ForumsRTSC for ECU
https://www.eclipse.org/forums/index.php/mv/msg/281/723/#msg_723
wiki docs. When you say Real-Time Software Components, do you consider
software for critical systems like Engine Management (also Electronic
Control Unit)? http://www.eclipse.org/projects/project_summary.php?projecti d=dsdp.rtsc
talks about Rich Client Platform. May I know the exact role Eclipse RCP is
playing in RTSC? Do you know if any of the projects in DSDP is going to
address (or addressing) using Java for embedded developement (as in ECU)?]]>Velganesh Subramanian2008-12-29T05:55:24-00:00Re: RTSC for ECU
https://www.eclipse.org/forums/index.php/mv/msg/281/729/#msg_729
> Hello, I just want a clarification on RTSC since I am not able to open
> the wiki docs.
Thanks for pointing this out, the apache server seems to have crashed.
I've rebooted it and the RTSC-Pedia should now be accessible.
> consider software for critical systems like Engine Management (also
> Electronic Control Unit)?
Yes. In fact, the RTSC model allows one to easily create a single
component that can support both a "traditional" dynamic runtime as well
as a static runtime which does not allow dynamic memory allocation such
as that dictated by MISRA.
> is playing in RTSC?
In our case, the rich client platform is used during two potentially
very different times:
1. during development of a component - in this case, the RCP is
your workstation
2. monitoring the real-time operation of a deployed component - in
this case the RCP can be either your workstation or an embedded
processor running something like eRCP
( http://www.eclipse.org/projects/project_summary.php?projecti d=rt.ercp).
