Eclipse Community ForumsExternal Application Text input error with unix location path as parameter value
https://www.eclipse.org/forums/index.php/mv/msg/275871/778277/#msg_778277
/path/to/a/folder
I have tried setting the parameter value with:
'/path/to/a/folder'
\\/path\\/to\\/a\\/folder
"/path/to/a/folder'
but they are failed. It worked when I enter just a single word as the parameter value. Please let me know what I have missed out. Thanks!
]]>Claire Lee2012-01-12T05:59:33-00:00Re: External Application Text input error with unix location path as parameter value
https://www.eclipse.org/forums/index.php/mv/msg/275871/778283/#msg_778283
As described in the documentation for this action (under this link, (search for "External Input Text (Application)" in the file), the external input text for SWT and RCP can only enter ASCII characters.
For your case here, I'd recommend building a module that copies the path you want to the clipboard and then using external key combination to paste it in the field with Ctrl+V or Mod1+V.
HTH,
Alex]]>Alexandra Schladebeck2012-01-12T07:00:49-00:00Re: External Application Text input error with unix location path as parameter value
https://www.eclipse.org/forums/index.php/mv/msg/275871/778296/#msg_778296
Claire Lee2012-01-12T08:11:23-00:00
