Eclipse Community Forumsstarting eclipse on Linux
https://www.eclipse.org/forums/index.php/mv/msg/274028/775862/#msg_775862
I've updated the eclipse.ini with:
-vm
/usr/lib/jvm/jre/bin/java
when I type ecplipse at the command line I get:
william@linux-1ro8:~/Documents/eclipse> eclipse
If 'eclipse' is not a typo you can use command-not-found to lookup the package that contains it, like this:
cnf eclipse
eclipse shon as executable:
william@linux-1ro8:~/Documents/eclipse> ls -l
total 604
drwxr-xr-x 2 william users 4096 Sep 15 22:13 about_files
-rw-r--r-- 1 william users 18909 Sep 9 14:21 about.html
-rw-r--r-- 1 william users 76985 Sep 15 22:13 artifacts.xml
drwxr-xr-x 4 william users 4096 Sep 15 22:13 configuration
drwxr-xr-x 2 william users 4096 Sep 15 22:13 dropins
-rwxr-xr-x 1 william users 71023 Mar 21 2011 eclipse
-rw-r--r-- 1 william users 448 Jan 6 14:54 eclipse.ini
-rw-r--r-- 1 william users 16536 Feb 25 2005 epl-v10.html
drwxr-xr-x 31 william users 4096 Sep 15 22:13 features
-rw-r--r-- 1 william users 9022 Dec 11 2006 icon.xpm
-rwxr-xr-x 1 william users 335360 Dec 11 2006 libcairo-swt.so
-rw-r--r-- 1 william users 8951 Feb 4 2011 notice.html
drwxr-xr-x 5 william users 4096 Sep 15 22:12 p2
drwxr-xr-x 13 william users 32768 Sep 15 22:13 plugins
drwxr-xr-x 2 william users 4096 Sep 15 22:13 readme
Thanks, Will
]]>will becchina2012-01-06T20:20:17-00:00Re: starting eclipse on Linux
https://www.eclipse.org/forums/index.php/mv/msg/274028/775887/#msg_775887
David Wegener2012-01-06T21:39:35-00:00Re: starting eclipse on Linux
https://www.eclipse.org/forums/index.php/mv/msg/274028/775906/#msg_775906
Trying the current directory option I get:
]]>will becchina2012-01-06T22:53:00-00:00Re: starting eclipse on Linux
https://www.eclipse.org/forums/index.php/mv/msg/274028/776501/#msg_776501
Nitin Dahyabhai2012-01-08T15:59:31-00:00Re: starting eclipse on Linux
https://www.eclipse.org/forums/index.php/mv/msg/274028/776631/#msg_776631
No - 64 bit machine.
I am running through Oracle VM VirtualBox.
Any issue there?
]]>will becchina2012-01-09T00:08:09-00:00Re: starting eclipse on Linux
https://www.eclipse.org/forums/index.php/mv/msg/274028/777092/#msg_777092
I installed the 32 bit Eclipse, and it launches. I'll see how it holds up.
