Caused by:(5) org.eclipse.persistence.exceptions.IntegrityException
Descriptor Exceptions:
Exception [EclipseLink-93] (Eclipse Persistence Services - 2.1.3.v20110304-r9073): org.eclipse.persistence.exceptions.DescriptorException
Exception Description: The table [FOO] is not present in this descriptor.
Descriptor: RelationalDescriptor(mypackage.Doo --> [DatabaseTable(DOO)])
Runtime Exceptions:
java.lang.IndexOutOfBoundsException: Index: 0, Size: 0
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:471)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.initializeDescriptors(DatabaseSessionImpl.java:406)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.postConnectDatasource(DatabaseSessionImpl.java:666)
at org.eclipse.persistence.internal.sessions.DatabaseSessionImpl.loginAndDetectDatasource(DatabaseSessionImpl.java:615)
at org.eclipse.persistence.internal.jpa.EntityManagerFactoryProvider.login(EntityManagerFactoryProvider.java:228)
... (6 lines)
at weblogic.deployment.QueryProxyImpl.getResultList(QueryProxyImpl.java:124)
at com.xyz.util.crud.CrudBDImpl.lista(CrudBDImpl.java:161)
at com.xyz.util.crud.CrudBDImpl.lista(CrudBDImpl.java:179)
at mypackage.aluno.AlunoRNImpl.lista(AlunoRNImpl.java:115)
Caused by:(4) org.eclipse.persistence.exceptions.JPQLException
Exception Description: Error compiling the query [Doo.lista: select c from Doo c WHERE c.tituloCur LIKE :tituloCur AND c.vlrPreco = :vlrPreco], line 1, column 32: unknown state or association field [tituloCur] of class [mypackage.ed.Doo].
at org.eclipse.persistence.exceptions.JPQLException.unknownAttribute(JPQLException.java:457)
at org.eclipse.persistence.internal.jpa.parsing.DotNode.validate(DotNode.java:88)
at org.eclipse.persistence.internal.jpa.parsing.LikeNode.validate(LikeNode.java:43)
at org.eclipse.persistence.internal.jpa.parsing.Node.validate(Node.java:91)
at org.eclipse.persistence.internal.jpa.parsing.LogicalOperatorNode.validate(LogicalOperatorNode.java:39)
... (19 lines)
