Eclipse Community ForumsHide Crosstab columns at runtime
https://www.eclipse.org/forums/index.php/mv/msg/260273/752386/#msg_752386
I need to integrate a report into my software. The report design must be
developable in the birt editor (done by customers w/o programming
knowledge). Can I modify the crosstab from the static .rptdesign (template)
at runtime, so that the end-user can select the columns of interest and then
generate the report?
Many thanks in advance,
Florian]]>Eclipse2011-10-26T11:25:59-00:00Re: Hide Crosstab columns at runtime
https://www.eclipse.org/forums/index.php/mv/msg/260273/752847/#msg_752847
Jason
On 10/26/2011 7:25 AM, Eclipse wrote:
> Dear Community,
> (template) at runtime, so that the end-user can select the columns of
> interest and then generate the report?
> Florian]]>Jason Weathersby2011-10-26T14:40:34-00:00Re: Hide Crosstab columns at runtime
https://www.eclipse.org/forums/index.php/mv/msg/260273/753691/#msg_753691
I'm fairly new to Birt, so it may take a while to examine your example. I
will return to you asap.
Thank you,
Florian
"Jason Weathersby" <jasonweathersby@windstream.net> schrieb im Newsbeitrag
news:j895dk$7ji$3@news.eclipse.org...
> Do you mean like the attached report?
> Jason
>> Dear Community,
>> Florian
>]]>Eclipse2011-10-28T11:16:39-00:00Re: Hide Crosstab columns at runtime
https://www.eclipse.org/forums/index.php/mv/msg/260273/756889/#msg_756889
I finally made it. Thank you!
Florian
"Eclipse" <gehrke@kapelan.com> schrieb im Newsbeitrag
news:j8e277$pfh$1@news.eclipse.org...
> Hi Jason,
> Thank you,
> Florian
>> Jason
>>> Dear Community,
>>> Florian
>]]>Eclipse2011-11-15T12:46:55-00:00
