Eclipse Community Forums[ATL] How to Compile a *.atl to .*asm via Java Code?
https://www.eclipse.org/forums/index.php/mv/msg/25398/82225/#msg_82225
Originally posted by: melycat.gmail.com
Hello
How to Compile an *.atl to .*asm via Java Code?
I've tried instantiate an AtlCompile, however I can't to call the method
"compile".
This method needs two arguments: an InputStream class and IFile class.
How can I do this?
best regards.
Melyssa.]]>2008-05-26T20:47:39-00:00Re: [ATL] How to Compile a *.atl to .*asm via Java Code?
https://www.eclipse.org/forums/index.php/mv/msg/25398/82251/#msg_82251
Originally posted by: freddy.allilaire.univ-nantes.fr
--------------030603020000030703030308
Melyssa a ]]>2008-05-26T23:14:20-00:00Re: [ATL] How to Compile a *.atl to .*asm via Java Code?
https://www.eclipse.org/forums/index.php/mv/msg/25398/82385/#msg_82385
