Eclipse Community ForumsRe: Xdebug stopped breaking breakpoints
https://www.eclipse.org/forums/index.php/mv/msg/24775/80258/#msg_80258
Originally posted by: yfreeman.gmail.com
Thanks for the reply
> Couple of things to check
> 1. have a look at the FAQ on http://www.xdebug.org. There is a specific entry for XAMPP which may be
applicable
I looked at the FAQ and the Zend Optimizer had already been disabled. The Debugger was working for months and now I have this problem.
> 2. If you have any watch expressions, try deleting them. A Script can be terminated abnormally if
you have a watch expression enabled that does something like invoke an undefined function.
I'm assuming that would be in the "expressions" tab/view. Its empty
Only one breakpoint (besides for the "Break First Line" setting)
Another interesting thing is that when I start the debug process in a browser (through the eclipse debug button) and the page loads, and then I load another page or reload the same page the Eclipse window pops into view like it's trying to display something, but nothing is displayed.
--------------= Posted using GrabIt =----------------
------= Binary Usenet downloading made easy =---------
-= Get GrabIt for free from http://www.shemes.com/ =-]]>2008-09-15T18:19:51-00:00Re: Xdebug stopped breaking breakpoints
https://www.eclipse.org/forums/index.php/mv/msg/24775/80273/#msg_80273
step into which should cause it to stop at the first line, but xdebug for some reason says straight
after that it is stopping. This would happen if it had reached the end of the script or I am
guessing would also occur it there was some sort of error in the php engine trying to execute the
script. Could you post the file c:\projects\drupal\index.php (this is the file xdebug sees is
executing) there may be clue there.
Dave Kelsey
> applicable
>]]>D Kelsey2008-09-15T19:50:20-00:00
