Eclipse Community ForumsTransfer object mappings
https://www.eclipse.org/forums/index.php/mv/msg/246287/736646/#msg_736646
I have a couple of different versions of the same application. This means one AUT per version. The objects are the same between the versions and I don't want to redo the mapping for every version, so the question is how to transfer the mappings between the different versions? The object mapping is started per AUT, so I don't see the old mappings if I start a new AUT.
Regards Richard]]>Richard Skoog2011-10-14T07:31:11-00:00Re: Transfer object mappings
https://www.eclipse.org/forums/index.php/mv/msg/246287/736675/#msg_736675
If it's the same application but in a different version, then I'd recommend using different AUT configurations. Different AUTs have different Object Maps, but one AUT can have different configurations (versions, platforms etc.). The configurations then all share an object map.
HTH!
Alex]]>Alexandra Schladebeck2011-10-14T08:06:45-00:00Re: Transfer object mappings
https://www.eclipse.org/forums/index.php/mv/msg/246287/736807/#msg_736807
]]>Richard Skoog2011-10-14T10:58:29-00:00Re: Transfer object mappings
https://www.eclipse.org/forums/index.php/mv/msg/246287/741225/#msg_741225
Rahat 2011-10-19T10:04:10-00:00Re: Transfer object mappings
https://www.eclipse.org/forums/index.php/mv/msg/246287/741228/#msg_741228
Lets suppose we have done some mapping in one project and have made reusable modules in it. But when I try to use these reusable modules in other project, it gives me the error for object mapping not found. And then I can see all the objects in the "Unassigned Component names". Do I always need to Assign these objects again and again whenever I will use these reusable modules in other project especially on another system ?
Rahat]]>Rahat 2011-10-19T10:08:48-00:00Re: Transfer object mappings
https://www.eclipse.org/forums/index.php/mv/msg/246287/741321/#msg_741321
at this moment there is no chance to reuse the object mapping done in a reused project in a reusing project since the mapping is bound to the AUT and the project.
Oliver]]>Oliver Goetz2011-10-19T12:23:59-00:00Re: Transfer object mappings
https://www.eclipse.org/forums/index.php/mv/msg/246287/742091/#msg_742091
so what is best approach to solve this problem ?
Rahat]]>Rahat 2011-10-20T06:54:36-00:00Re: Transfer object mappings
https://www.eclipse.org/forums/index.php/mv/msg/246287/1018339/#msg_1018339
Rahat wrote on Wed, 19 October 2011 06:08
Alex,
Rahat
Did some solution for this problem appeared in the meantime?]]>Miroslav Jankovic2013-03-13T16:30:17-00:00Re: Transfer object mappings
https://www.eclipse.org/forums/index.php/mv/msg/246287/1066721/#msg_1066721
Alex,
Rahat
We have several team members to write test cases at the same time so some reusable modules would make it easy to organize the work. Is there a good way to reuse OM yet?
