Eclipse Community Forumsinstall fails in eclipse classic/java developers
https://www.eclipse.org/forums/index.php/mv/msg/245203/734764/#msg_734764
ive installed egit on a 32bit linux system without problems, but i cant install egit on a 32bit windows machine in the current eclipse.
eclipse classis and eclipse for java developers both say:
Unable to connect to repository http___download.eclipse.org/egit/updates/content.xml
Connection refused: connect
why is that?
NOTE: http___ is of course http semocilon slash slash, the forum does not allow users with less than 5 posts to post links.
]]>julius 2011-10-09T20:32:21-00:00Re: install fails in eclipse classic/java developers
https://www.eclipse.org/forums/index.php/mv/msg/245203/734789/#msg_734789
http://download.eclipse.org from this machine ?
- Maybe you are behind a firewall and need to adjust Eclipse proxy settings ?]]>Matthias Sohn2011-10-09T23:10:50-00:00Re: install fails in eclipse classic/java developers
https://www.eclipse.org/forums/index.php/mv/msg/245203/734958/#msg_734958
but outgoing connections are not a problem, i can retrieve the content from http___download.eclipse.org/egit/updates/ with firefox.
in general -> netweork connections -> active provider is set to native.
in proxy entries is one active, HTTP 127.0.0.1 57717 native false
i did not change these settings...but this cant be a eclipse default? or does eclipse come with its own proxy software?
EDIT: setting this option to direct and installing worked]]>julius 2011-10-10T14:20:54-00:00Re: install fails in eclipse classic/java developers
https://www.eclipse.org/forums/index.php/mv/msg/245203/736126/#msg_736126
Matthias Sohn2011-10-13T16:10:17-00:00
