Eclipse Community ForumsHow to add parameters to CommandContributionItemParameter
https://www.eclipse.org/forums/index.php/mv/msg/244916/734307/#msg_734307
I want to add parameters to a CommandContributionItemParameter. I have the following code:
This does not throw an Exception but the CommandContributionItem I create from this paramater is not displayed in the context menu. It is displayed when not passing parameters to it. Is there a convenient way to pass parameters to my CommandContributionItemParameter?
Ralph]]>Ralph Gerbig2011-10-07T12:14:50-00:00Re: How to add parameters to CommandContributionItemParameter
https://www.eclipse.org/forums/index.php/mv/msg/244916/753484/#msg_753484
PW
]]>Paul Webster2011-10-27T12:49:14-00:00Re: How to add parameters to CommandContributionItemParameter
https://www.eclipse.org/forums/index.php/mv/msg/244916/753487/#msg_753487
I found out that I need to have parameters connected to my command in plugin.xml. These ones I connected to parameter converters. This works fine for me. Thanks for
your reply.
