Eclipse Community ForumsIncluding library and dependencies
https://www.eclipse.org/forums/index.php/mv/msg/239095/723450/#msg_723450
I installed Boost in my Linux, included it in my project and some boost`s command (example BOOST_FOREACH) are working perfectly.
But, I can't run the example I downloaded from codeproject and I believe that it's happening because I don't know how properly include libraries in Eclipse. Could someone indicate me how to include libraries in Eclipse? I have no idea how use GCC C++ Compiler and GCC C++ Linker on Properties>>Settings window. I know that there are difference between previous compiled code and already compiled code.
I could include Boost and Curl because I followed some tutorials, but I don't know exactly what I have done. And, now, I couldn't run the codeproject example in Eclipse/linux as I've done in Visual Studio.
If someone know some tutorial for begginers about which options exists and how to do about including new libraries and dependencies on Eclipse will be very helpful. If someone has already used the Spirit library and could give some suggestion about make the example work on Eclipse/Linux, it will be nice as well.]]>demetrio 2011-09-08T15:17:11-00:00Re: Including library and dependencies
https://www.eclipse.org/forums/index.php/mv/msg/239095/723671/#msg_723671
http://wiki.eclipse.org/CDT/User/FAQ#Adding_C.2FC.2B.2B_External_Libraries]]>Axel Mueller2011-09-09T06:32:36-00:00
