Eclipse Community ForumsDynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/720979/#msg_720979
Originally posted by: Mirko Swillus
Hej,
I'm trying to render a SVG image that is provided as a byte array within
a DataSource, target format is PDF. All the PDF says, is
"Current report item is not supported in this report format."
When I put a JPG as a byte array into the DataSources property
'row["Image"]' (see rptdesign below) everything works fine. Furthermore,
adding an embedded SVG image works, too.
I guess I have to specify the images mime type ("image/svg+xml"), image
type or file extension, but I have no glue how to do it. All I tried
concerning this failed.
Please find the interesting part of my .rptdesign below. Thanks in advance,
<list-property name="boundDataColumns">
<structure>
<property name="name">Image</property>
<expression name="expression"
type="javascript">dataSetRow["Image"]</expression>
<property name="dataType">javaObject</property>
</structure>
</list-property>
<structure name="toc"/>
<property name="source">expr</property>
<expression name="valueExpr">row["Image"]</expression>
</image>
</body>
============================================]]>2011-08-31T15:54:38-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/721115/#msg_721115
I was able to read one from a file in the image onCreate script like:
importPackage(Packages.java.io);
importPackage(Packages.java.lang);
var file = new File("C:/work/workspaces/2.6.1workspaces/BIRT -
Reports/BIRT Reports/resources/spain.svg");
var ist = new FileInputStream(file);
var lengthi = file.length();
bytesa = new ByteArrayOutputStream( lengthi);
var c;
while((c=ist.read()) != -1){
bytesa.write(c);
} ist.close();
this.data = bytesa.toByteArray();
Jason
On 8/31/2011 11:54 AM, Mirko Swillus wrote:
> Hej,
> Mirko Swillus
> <body>
> <image name="name_blue" id="15">
> <property name="height">3.15625in</property>
> <property name="width">7.583333333333333in</property>
> <property name="dataSet">Data Set</property>
> <structure>
> </structure>
> </list-property>
> </image>
> </body>
>]]>Jason Weathersby2011-08-31T22:28:40-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/721269/#msg_721269
Jason,
Am 01.09.2011 00:28, schrieb Jason Weathersby:
> Have you set the data type to blob and tried it?
thanks for your answer, but changing 'javaObject' to 'blob' makes no
difference.
But I managed to solve the problem, with the help of [0]. As I guessed
yesterday, I had to set the MIME type explicitly, since BIRT obviously
has problems to resolve the image type itself when overhanding a SVG as
a byte array (at least within my BIRT 3.7 runtime here, providing a JPG
the same way works fine).
The resulting part of my .rptdesign looks like this now:
> var c;
> bytesa.write(c);
> } ist.close();
> Jason
>> Hej,
>> advance,
>> Mirko Swillus
>> <body>
>> <structure>
>> </structure>
>> </list-property>
>> </image>
>> </body>
>]]>2011-09-01T09:50:24-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/721387/#msg_721387
Jason
On 9/1/2011 5:50 AM, Mirko Swillus wrote:
> Jason,
> difference.
> <body>
> <image name="some" id="15">
> <structure>
> </structure>
> </list-property>
> <expression name="typeExpr">"image/svg+xml"</expression>
> </image>
> </body>
> Mind the <expression name="typeExpr">"image/svg+xml"</expression>.
> Quotes are required because it has to be a valid JavaScript Expression.
> Regards,
> Mirko Swillus
> [0]
> http://www.eclipse.org/birt/ref/rom/elements/Image.html#Property-typeExpr
> > var c;
> > bytesa.write(c);
> > } ist.close();
> > Jason
> >> Hej,
> within
> Furthermore,
> >> advance,
> >> Mirko Swillus
> >> <body>
> >> <structure>
> >> </structure>
> >> </list-property>
> >> </image>
> >> </body>
>]]>Jason Weathersby2011-09-01T16:01:27-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/777630/#msg_777630
Chris Harrington2012-01-10T20:57:34-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/778399/#msg_778399
Jason
On 1/10/2012 3:57 PM, Chris Harrington wrote:
> I tried setting typeExpr to "image/svg+xml" but am not getting the SVG
> to display. Same code works for PNG, and SVG url works if is static.
> What might I check?]]>Jason Weathersby2012-01-11T17:28:13-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/778713/#msg_778713
Chris Harrington2012-01-13T17:19:27-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/778715/#msg_778715
First, I tried using it directly:
var t = new Packages.org.apache.batik.transcoder.image.PNGTranscoder();
var file = new File("C:/Users/chris/Downloads/helloworld.svg");
var s = new Packages.java.lang.String(ist.toString());
var bais = new Packages.java.io.ByteArrayInputStream(s.getBytes());
var input = new Packages.org.apache.batik.transcoder.TranscoderInput(bais);
var baos = new Packages.java.io.ByteArrayOutputStream();
var output = new Packages.org.apache.batik.transcoder.TranscoderOutput(baos);
t.transcode(input, output);
this.data = baos.toByteArray();
JavaException org.apache.batik.transcoder.TranscoderException: null
Enclosed Exception
Content is not allowed in prolog.
]]>Chris Harrington2012-01-13T17:28:02-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/778775/#msg_778775
Jason
On 1/13/2012 12:28 PM, Chris Harrington wrote:
> I also tried doing it in onCreate()
> -- begin code --
> var c;
> bytesa.write(c);
> ist.close();
> -- end code --
> The SVG wasn't displayed and there was no error
> Then since I wasn't sure if it needed to be transcoded, I tried:
> -- begin code --
> try {
> var output = new
> } catch (e) {
> Packages.javax.swing.JOptionPane.showMessageDialog(null, e);
> -- end code --
> This resulted in the error
> Enclosed Exception
>]]>Jason Weathersby2012-01-13T19:57:23-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/778804/#msg_778804
It runs without error, but it didn't render the SVN. I've attached an image of the output.
I installed the BIRT reporting version of Eclipse about two weeks ago, so I should be current. I've also attached a dump of my configuration.
Many thanks for your assistance!
- Chris
]]>Chris Harrington2012-01-13T21:46:25-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/778838/#msg_778838
I noticed that your report file has BIRT Designer Version 2.6.1, and I am using Version 3.7.1. Is that relevant?
What I am ultimately needing to do is modify an SVG template based upon data fields. I think the options are
a) request an SVG via a url with a querystring, and have a the servlet load, modify, and return the SVG
b) load an SVG in the onRender event and using script modify the SVG DOM before transcoding
c) some other approach I haven't considered.
But first I need to get working a simple example of a dynamic SWF.]]>Chris Harrington2012-01-13T23:20:11-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/780355/#msg_780355
This worked for me in 3.7.1 as well. Can you look at your preferences:
Window->preferences->Report Design->Preview and check the box to Always
use external browsers. Then click on the Web Browser link below the
checkbox to verify that it is using firefox?
Jason
On 1/13/2012 6:20 PM, Chris Harrington wrote:
> Hi Jason,
> before transcoding
> But first I need to get working a simple example of a dynamic SWF.]]>Jason Weathersby2012-01-17T16:48:47-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/781116/#msg_781116
That did the trick. Thanks much for your assistance.
- Chris
]]>Chris Harrington2012-01-20T15:21:23-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/782891/#msg_782891
I can do this to load an image from a URL:
But I can't figure out how to do the same for an SVG image. Thanks for any guidance.
- Chris]]>Chris Harrington2012-01-24T16:48:12-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/783012/#msg_783012
like:
var myurl = new Packages.java.net.URL("yoururltosvg");
this.URI = myurl;
Jason
On 1/24/2012 11:48 AM, Chris Harrington wrote:
> How to load SVG from a URL?
> try {
> importPackage(Packages.java.net);
> importPackage(Packages.javax.imageio);
> var myurl = new Packages.java.net.URL("http://localhost/welcome.png");
> var img = ImageIO.read(myurl);
> bas = new ByteArrayOutputStream();
> ImageIO.write(img, "png", bas);
> this.data = bas.toByteArray();
> } catch (e) {
> any guidance.
> - Chris]]>Jason Weathersby2012-01-24T22:32:53-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/783928/#msg_783928
Chris Harrington2012-01-26T19:07:52-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/783933/#msg_783933
Method 1:
var file = new File("C:/inetpub/wwwroot/spaceship3.svg");
var c;
bytesa.write(c);
ist.close();
results:
In report viewer, the SVG image is displayed. The render quality is high. Onload()
script in SVG is executted and rendered results reflect DOM operations done in script.
In PDF, the SVG image is displayed but the transparency is lost (transparency was
present in web viewer). Onload() script operations are not reflected in rendered
results.
var input = new Packages.org.apache.batik.transcoder.TranscoderInput(inp);
results:
The SVG is rendered in the report viewer. Rendering quality is not as good
as in Method 2. Transparency is rendered properly. Onload() script in SVG
in not reflected in rendering.
In the PDF, rendering quality is not so good, transparency works, onload() is
not reflected in results.
]]>Chris Harrington2012-01-26T19:26:40-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/784503/#msg_784503
Jason
On 1/26/2012 2:26 PM, Chris Harrington wrote:
> Here's more details on my results so far. Some things work properly with
> some methods, but there are certainly lots of issues.
> Method 1:
> code:
> var c;
> bytesa.write(c);
> ist.close();
> results:
> high. Onload()
> done in script.
> (transparency was
> rendered
> results.
> Method 2:
> code:
> var url = new
> Packages.java.net.URL("http://localhost/sendsvg.aspx?score=5&m=3&sd=2");
> this.URI = url;
> results:
> The SVG image is not rendered.
> Method 3:
> code:
> var url = new
> var conn = url.openConnection();
> var inp = conn.getInputStream();
> var output = new
> results:
> onload() is
>]]>Jason Weathersby2012-01-27T16:17:45-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/784550/#msg_784550
Chris Harrington2012-01-27T17:30:51-00:00Re: Dynamic SVG Image: Item is not supported
https://www.eclipse.org/forums/index.php/mv/msg/237893/786589/#msg_786589
Can you open a bugzilla request for this?
Jason
On 1/27/2012 12:30 PM, Chris Harrington wrote:
> Yes.]]>Jason Weathersby2012-01-30T15:56:55-00:00Re: base64 image is not rendering in pdf
https://www.eclipse.org/forums/index.php/mv/msg/237893/1403237/#msg_1403237
I have Two problems in BIRT
1.I have base64 image url I am able view the imag ein BIRT viewer but when i download as pdf.Its showing as error The resource of this report item is not reachable.
2 . I am not able to pass base64 link as a parameter
Kindly help in this
Example base64 link :
data:image/jpeg;base64,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 ]]>Padmasridhar c2014-07-22T15:00:02-00:00
