Eclipse Community ForumsQuestion "Can OSEE be used offline and later sync'd up?"
https://www.eclipse.org/forums/index.php/mv/msg/2350/6837/#msg_6837
database artifacts, work offline and then sync up when re-connected, it
was certainly a consideration in the design. The most complex part would
be resolving conflicts that may occur to artifacts edited in both
disconnected OSEE's. Since OSEE already has the capability to run on
multiple databases and the capability to export and import artifacts, it
would just take some effort to provide the first versions of this
feature. This would be a great area for collaboration.]]>Donald Dunne2008-04-22T21:39:31-00:00Re: Question "Can OSEE be used offline and later sync'd up?"
https://www.eclipse.org/forums/index.php/mv/msg/2350/11833/#msg_11833
This sounds like a Subversion opportunity. SVN provides for both DB and
FSFS. But I am sure everyone here is familiar with SVN. Does OSEE
provide for both methods?]]>Ray Joseph2009-03-25T10:57:28-00:00Re: Question "Can OSEE be used offline and later sync'd up?"
https://www.eclipse.org/forums/index.php/mv/msg/2350/572368/#msg_572368
