<project xmlns="http:/ /maven.apache.org/POM/4.0.0" xmlns:xsi="http:/ /www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http:/ /maven.apache.org/POM/4.0.0 http:/ /maven.apache.org/maven-v4_0_0.xsd">
<modelVersion>4.0.0</modelVersion>
<groupId>org.example.domainmodel</groupId>
<artifactId>org.example.domainmodel</artifactId>
<packaging>jar</packaging>
<version>1.0-SNAPSHOT</version>
<name>my-app</name>
<url>http:/ /maven.apache.org</url>
<dependencies>
<dependency>
<groupId>org.eclipse</groupId>
<artifactId>xtext</artifactId>
<version>2.0.0</version>
</dependency>
<dependency>
<groupId>org.apache</groupId>
<artifactId>log4j</artifactId>
<version>1.2.15</version>
</dependency>
<dependency>
<groupId> org.apache</groupId>
<artifactId>commons.logging</artifactId>
<version>1.0.4</version>
<optional>true</optional>
</dependency>
<dependency>
<artifactId>xtext.generator</artifactId>
</dependency>
<dependency>
<artifactId>emf.codegen.ecore</artifactId>
<version>2.7.0</version>
</dependency>
<dependency>
<artifactId>emf.mwe.utils</artifactId>
<version>1.1.0</version>
</dependency>
<dependency>
<artifactId>emf.mwe2.launch</artifactId>
</dependency>
<dependency>
<artifactId>xtext.util</artifactId>
</dependency>
<dependency>
<artifactId>emf.ecore</artifactId>
</dependency>
<dependency>
<artifactId>emf.common</artifactId>
</dependency>
<dependency>
<groupId>org.antlr</groupId>
<artifactId>runtime</artifactId>
<version>3.2.0</version>
</dependency>
<dependency>
<artifactId>xtext.common.types</artifactId>
</dependency>
</dependencies>
<build>
<resources>
<resource>
<directory>src</directory>
</resource>
</resources>
</build>
</project>
Choose a number: 110: Choose version:
1: 1.0-alpha-1
2: 1.0-alpha-2
3: 1.0-alpha-3
4: 1.0-alpha-4
5: 1.0
6: 1.1
Choose a number: 6:
[INFO] Using property: groupId = org.example.domainmodel
[INFO] Using property: artifactId = org.example.domainmodel
[INFO] Using property: version = 1.0-SNAPSHOT
[INFO] Using property: package = true
Confirm properties configuration:
groupId: org.example.domainmodel
artifactId: org.example.domainmodel
version: 1.0-SNAPSHOT
package: true
Y: :
[INFO] -------------------------------------------------------------------------
[INFO] Using following parameters for creating project from Old (1.x) Archetype:
maven-archetype-quickstart:1.1
[INFO] Parameter: groupId, Value: org.example.domainmodel
[INFO] Parameter: packageName, Value: true
[INFO] Parameter: package, Value: true
[INFO] Parameter: artifactId, Value: org.example.domainmodel
[INFO] Parameter: basedir, Value: C:\Work\MavenExporter\org.example.domainmodel
[INFO] Parameter: version, Value: 1.0-SNAPSHOT
[ERROR] Unable to add module to the current project as it is not of packaging ty
pe 'pom'
org.apache.maven.archetype.old.ArchetypeTemplateProcessingException: Unable to a
dd module to the current project as it is not of packaging type 'pom'
at org.apache.maven.archetype.old.DefaultOldArchetype.createArchetype(De
faultOldArchetype.java:313)
at org.apache.maven.archetype.generator.DefaultArchetypeGenerator.proces
sOldArchetype(DefaultArchetypeGenerator.java:142)
at org.apache.maven.archetype.generator.DefaultArchetypeGenerator.genera
teArchetype(DefaultArchetypeGenerator.java:110)
teArchetype(DefaultArchetypeGenerator.java:149)
teArchetype(DefaultArchetypeGenerator.java:209)
at org.apache.maven.archetype.DefaultArchetypeManager.generateProjectFro
mArchetype(DefaultArchetypeManager.java:71)
at org.apache.maven.archetype.mojos.CreateProjectFromArchetypeMojo.execu
te(CreateProjectFromArchetypeMojo.java:190)
at org.apache.maven.plugin.DefaultBuildPluginManager.executeMojo(Default
BuildPluginManager.java:101)
at org.apache.maven.lifecycle.internal.MojoExecutor.execute(MojoExecutor
.java:209)
.java:153)
.java:145)
at org.apache.maven.lifecycle.internal.LifecycleModuleBuilder.buildProje
ct(LifecycleModuleBuilder.java:84)
ct(LifecycleModuleBuilder.java:59)
at org.apache.maven.lifecycle.internal.LifecycleStarter.singleThreadedBu
ild(LifecycleStarter.java:183)
at org.apache.maven.lifecycle.internal.LifecycleStarter.execute(Lifecycl
eStarter.java:161)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:319)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:156)
at org.apache.maven.cli.MavenCli.execute(MavenCli.java:537)
at org.apache.maven.cli.MavenCli.doMain(MavenCli.java:196)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:141)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.
java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAcces
sorImpl.java:25)
at org.codehaus.plexus.classworlds.launcher.Launcher.launchEnhanced(Laun
cher.java:290)
at org.codehaus.plexus.classworlds.launcher.Launcher.launch(Launcher.jav
a:230)
at org.codehaus.plexus.classworlds.launcher.Launcher.mainWithExitCode(La
uncher.java:409)
at org.codehaus.plexus.classworlds.launcher.Launcher.main(Launcher.java:
352)
[INFO]
[INFO] Skipping my-app
[INFO] This project has been banned from the build due to previous failures.
[INFO] BUILD FAILURE
[INFO] Total time: 12.375s
[INFO] Finished at: Wed Jul 20 11:27:22 CEST 2011
[INFO] Final Memory: 7M/17M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-archetype-plugin:2
.0:generate (default-cli) on project org.example.domainmodel: Unable to add modu
le to the current project as it is not of packaging type 'pom' -> [Help 1]
[ERROR]
[ERROR] To see the full stack trace of the errors, re-run Maven with the -e swit
ch.
[ERROR] Re-run Maven using the -X switch to enable full debug logging.
[ERROR]
[ERROR] For more information about the errors and possible solutions, please rea
d the following articles:
[ERROR] [Help 1] http:/ /cwiki.apache.org/confluence/display/MAVEN/MojoFailureExc
eption
