Eclipse Community Forums[buckminster-dev] Project meta data is out of date for tools.buckminster
https://www.eclipse.org/forums/index.php/mv/msg/218206/692697/#msg_692697
Originally posted by: emo
Henrik, Thomas,
Projects are required to keep meta data up to date using the MyFoundation
Portal (http://portal.eclipse.org/). The following problems were found
with this project's meta-data:
* The date for release "Indigo" is in the past, but the release is not
marked as completed. If it is completed, it should be marked as completed;
if it has been postponed, it should be given a new target date.]]>2011-07-05T04:00:23-00:00
