Eclipse Community Forums"Confirm Disable Builder" Dialog -how to access?
https://www.eclipse.org/forums/index.php/mv/msg/218068/692498/#msg_692498
Right click on a project and select "properties -> Builders", then deselect a builder and the "Confirm Disable Builder" should appear.
Nothing I do seems to allow SWTBot to access this dialog -- also, the who SWTBot process seems to hang up until I manually click the "OK" or "Cancel" buttons on this dialog (ie: SWTBot doesn't do the usual "timeout" with this dialog active.)
Sorry, not really a "Java developer", and have been away from SWTBot for a month or so, so I may be missing something real simple, but I've been able to access other dialogs similar to this with no problem, and as far as I know I am using the same techniques.
]]>David 2011-07-04T15:18:01-00:00Re: "Confirm Disable Builder" Dialog -how to access?
https://www.eclipse.org/forums/index.php/mv/msg/218068/694259/#msg_694259
I didn't find the eclipse class/plug-in that handles this specific dialog, and had not much time to investigate, so I can't say more.]]>Benjamin Ratiarisolo2011-07-08T08:18:10-00:00
