Eclipse Community ForumsNo application id has been found
https://www.eclipse.org/forums/index.php/mv/msg/210411/675377/#msg_675377
The following steps is my operation:
1, Create a RCP project on the "Eclipse RCP with a view" template
2, Add a product configuration.
now I "launch an eclipse applicatin" in product configration, it's ok,
then i add "org.eclipse.equinox.p2.ui.sdk" to "Dependencipes" in MANIFAST.MF,
"launch an eclipse applicatin" in "MANIFAST.MF" it's ok but "launch an eclipse applicatin" in product configration has a exception: No application id has been found,
when I add org.eclipse.equinox.p2.ui.sdk to Dependencies, then has a Exception: No application id has been found;
file:E:/RCP/.metadata/.plugins/org.eclipse.pde.core/pro.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.equinox.app 0 0 2011-05-31 18:23:45.015
!MESSAGE Product pro.product could not be found.
!ENTRY org.eclipse.osgi 2 0 2011-05-31 18:23:45.031
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2011-05-31 18:23:45.031
!MESSAGE Bundle initial@reference:file:E:/RCP/pro/ was not resolved.
!SUBENTRY 2 pro 2 0 2011-05-31 18:23:45.031
!MESSAGE Missing required bundle org.eclipse.equinox.p2.ui.sdk_1.0.100.
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!MESSAGE Bundle pro_1.0.0.qualifier [25] was not resolved.
!ENTRY org.eclipse.osgi 4 0 2011-05-31 18:23:45.031
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: No application id has been found.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:242)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
]]>wmhsss2011-05-31T10:34:37-00:00Re: No application id has been found
https://www.eclipse.org/forums/index.php/mv/msg/210411/728975/#msg_728975
Parvez Ahmad Hakim
Srinagar http://www.abobjects.com/
!ENTRY org.eclipse.equinox.app 0 0 2011-09-24 21:33:49.346
!MESSAGE Product org.cord.client.dms.mainapp.e4.product could not be found.
!ENTRY org.eclipse.osgi 4 0 2011-09-24 21:33:49.389
!STACK 1
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
An error has occurred. See the log file
D:\Commit-3.7SR1-RCP\project\.metadata\.plugins\org.eclipse.pde.core\org.cord.client.dms.mainapp.e4.product\1316880226818.log.
]]>Parvez Ahmad Ahmad2011-09-24T16:09:50-00:00Re: No application id has been found
https://www.eclipse.org/forums/index.php/mv/msg/210411/728976/#msg_728976
eclipse.buildId=unknown
java.version=1.6.0_11
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=in
Framework arguments: -product org.cord.client.dms.mainapp.e4.product
Command-line arguments: -product org.cord.client.dms.mainapp.e4.product -data D:\Commit-3.7SR1-RCP\project/../runtime-org.cord.client.dms.mainapp.e4.product -dev file:D:/Commit-3.7SR1-RCP/project/.metadata/.plugins/org.eclipse.pde.core/org.cord.client.dms.mainapp.e4.product/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!STACK 1
]]>Parvez Ahmad Ahmad2011-09-24T16:10:24-00:00
