Eclipse Community ForumsWhat command in Eclipse will compile Java test classes but would not run them)
https://www.eclipse.org/forums/index.php/mv/msg/204520/654057/#msg_654057
I created a Maven Build with Goals: clean install
I checked "Skip Tests"
It is building fine.
BUILD SUCCESSFUL
However when I am trying to execute JUnit test I am getting ClassNotFoundException on my JUnit class
Can anyone help?
Is there way in Eclipse (using maven plugin) to compile JUnit test classes without running them? From IDE, not using external maven command?
]]>No real name2011-02-13T19:21:15-00:00Re: What command in Eclipse will compile Java test classes but would not run them)
https://www.eclipse.org/forums/index.php/mv/msg/204520/654058/#msg_654058
Added to pom.xml:
