Eclipse Community ForumsCannot register my EPackage
https://www.eclipse.org/forums/index.php/mv/msg/202438/646834/#msg_646834
The "Register EPackages" item does not appear when I right click on my .ecore file.
I use Helios SR1 (Modeling) on Windows 7.
Has one any idea about what the cause could be?
Thanks in advance for your help.
Best regards.]]>sylvain.cambon2010-12-31T18:40:20-00:00Re: Cannot register my EPackage
https://www.eclipse.org/forums/index.php/mv/msg/202438/646867/#msg_646867
somewhere, you could use PDE Spy to try to determine where it's coming
from and then make sure you install that bundle/feature in your IDE.
sylvain.cambon@gmail.com wrote:
> Hello,
> The "register EPackages" item does not appear when I right click on my
> .ecore file.
> Best regards.]]>Ed Merks2011-01-01T19:24:02-00:00Re: Cannot register my EPackage
https://www.eclipse.org/forums/index.php/mv/msg/202438/753829/#msg_753829
To phrase the problem more generally: I want one of my ecore models to be registered with the EMF runtime so it appears at the Navigate->Open EPackage menu.
How can I do that?
]]>Michalis Famelis2011-10-29T04:08:29-00:00Re: Cannot register my EPackage
https://www.eclipse.org/forums/index.php/mv/msg/202438/753843/#msg_753843
> Same issue here (Indigo modeling, running on ubuntu).
> How can I do that? :)
I don't think EMF ships with this ability but maybe you're looking for the M2M/QVT Declarative Model Registry I quickly
googled on https://bugs.eclipse.org/bugs/show_bug.cgi?id=289759 .
