Eclipse Community ForumsNaming of generated .zip files from product
https://www.eclipse.org/forums/index.php/mv/msg/202330/646534/#msg_646534
I'm currently creating the build for the proposed eclipse RTP project.
So, first of all I want to say that it's pretty easy to create an
eclipse based build with tycho, good job!
But I'm stumbling with one issue regarding the naming of the created
product .zip files. i can explain this using the tycho-demo/itp04-rcp
example. When you run this build two zip file will be created. The name
of one of this files is:
example.product.id-linux.gtk.x86.zip
That's not what I need for my zip files. I need a format like this:
I searched a while for a solution but I can't find one. Can somebody
tell me how to affect the name of this archived zip files? Thanks in
advance.
Regards Holger
Holger Staudacher | EclipseSource Karlsruhe
Need professional support for RAP and RCP?
Go to: http://eclipsesource.com/support
Twitter : @hstaudacher
Blog : http://eclipsesource.com/blogs/tag/rap/]]>Holger Staudacher2010-12-28T09:07:19-00:00Re: Naming of generated .zip files from product
https://www.eclipse.org/forums/index.php/mv/msg/202330/647899/#msg_647899
using maven antrun plugin).
Not sure if we should make this configurable as we have potentially several
products and file names have to be unique across all configured
environments.
Once installed/deployed to a maven repo, the file name is always changed
anyway by maven to standard
<artifactid>-<version>-<classifier>.<extension>
which can't be configured as this is how maven locates artifacts.
Best Regards,
Jan
"Holger Staudacher" <hstaudacher@eclipsesource.com> wrote in message
news:ifc92n$g9m$1@news.eclipse.org...
> Hi all,
> I'm currently creating the build for the proposed eclipse RTP project. So,
> first of all I want to say that it's pretty easy to create an eclipse
> example. When you run this build two zip file will be created. The name of
> example.product.id-<version>-<buildType>-incubation-linux.gtk.x86-.zip
> I searched a while for a solution but I can't find one. Can somebody tell
> me how to affect the name of this archived zip files? Thanks in advance.
> Regards Holger
>]]>Jan Sievers2011-01-10T10:40:39-00:00Re: Naming of generated .zip files from product
https://www.eclipse.org/forums/index.php/mv/msg/202330/647900/#msg_647900
thanks for your answer. I solved teh problem using the maven assembly plugin.
> for now you will have to rename the zip file in a post-build step (e.g.
> environments.
> Best Regards,
> Jan
>> Hi all,
>> Regards Holger
Blog : http://eclipsesource.com/blogs/tag/rap/]]>Holger Staudacher2011-01-10T10:47:12-00:00Re: Naming of generated .zip files from product
https://www.eclipse.org/forums/index.php/mv/msg/202330/655357/#msg_655357
Can you point us to where RTP is exactly using this? I have so far seen no
further update on my question regarding the examples or automatically
deploying to an update site from Maven/Hudson with Tycho.
It works rather well manually for UOMo and the feature is also visually
integrated with Eclipse now, but having either the ZIP archive of that
feature or an update site built by Hudson would be great.
TIA,
Werner Keil | UOMo Lead]]>Werner Keil2011-02-19T19:39:03-00:00Re: Naming of generated .zip files from product
https://www.eclipse.org/forums/index.php/mv/msg/202330/655467/#msg_655467
RTP uses the assembly plugin to name the zip files and exclude some
files from the product during the install phase.
> Holger/Jan,
> no further update on my question regarding the examples or
> automatically deploying to an update site from Maven/Hudson with Tycho.
> TIA,
