Eclipse Community ForumsRunning SMILA as service
https://www.eclipse.org/forums/index.php/mv/msg/201780/644628/#msg_644628
atm I try to work out a concept for deploying SMILA at a production environment (Linux) where SMILA should start at automatically (init.d)
So far starting is not the problem - but how can I provide a sufficient way to stop SMILA and give a status?
Any hints?
Thanks in advance,
Martin]]>Martin Röbert2010-12-13T14:42:28-00:00Re: Runnin SMILA as service
https://www.eclipse.org/forums/index.php/mv/msg/201780/644645/#msg_644645
Originally posted by: juergen.schumacher.attensity.com
Am 13.12.2010, 15:42 Uhr, schrieb Martin <martin.roebert@gmx.de>:
> Hi there,
> Any hints?
Juergen.]]>2010-12-13T15:02:56-00:00Re: Running SMILA as service
https://www.eclipse.org/forums/index.php/mv/msg/201780/644752/#msg_644752
and thanks for that fast answer.
As you mentioned it I stumbled accross this FAQ-entry already but I never go it working for me - I couldn't connect via telnet to the port. Have you any hints regarding this issue?
Or any other suggestion to my problem
Thanks in advance,
Martin]]>Martin Röbert2010-12-14T07:00:21-00:00Re: Running SMILA as service
https://www.eclipse.org/forums/index.php/mv/msg/201780/644785/#msg_644785
> Have you any hints regarding this issue? Or any other suggestion to my
> problem ;)
> Thanks in advance,
> Martin
Apart from the usual suspects (firewall etc ....): not really (;
We are using this ourselves, though not via the SMILA.ini file but as a
command line parameter "-console 9005".
Ok, one idea: it must be placed before the -vmargs parameter.
Juergen.]]>2010-12-14T08:52:44-00:00Re: Running SMILA as service
https://www.eclipse.org/forums/index.php/mv/msg/201780/644809/#msg_644809
I'll give it a shot again
Martin]]>Martin Röbert2010-12-14T10:03:26-00:00Re: Running SMILA as service
https://www.eclipse.org/forums/index.php/mv/msg/201780/645469/#msg_645469
I am using this feature constantly via SMILA.ini, so it works for me
quite well.
Perhaps you did not put the port number in the new line _just right
after_ the "-console" definition?
For example, my SMILA.ini starts like this:
-console
9999
-noexit
-vmargs
-Xms40m
-Xmx1024m
Hope this helps.
Cheers
Igor
Am 14.12.2010 09:52, schrieb Jürgen Schumacher:
> Am 14.12.2010, 08:01 Uhr, schrieb Martin <martin.roebert@gmx.de>:
>> Hi,
>> port. Have you any hints regarding this issue? Or any other suggestion
>> to my problem ;)
>> Thanks in advance,
>> Martin
> Cheers,
> Juergen.]]>Igor Novakovic2010-12-17T10:28:46-00:00Re: Running SMILA as service
https://www.eclipse.org/forums/index.php/mv/msg/201780/645555/#msg_645555
thanks a lot for that hint. Got it working and wrote an init.d script which can stop it and query the status.
