Eclipse Community ForumsAvailability and usage of osgi-test-stubs
https://www.eclipse.org/forums/index.php/mv/msg/201725/644438/#msg_644438
The Virgo source has a a test bundle osgi-test-stubs, "OSGi Test Stubs". I have found bit of information about it, f.i. an 18 month old SpringSource blog "OSGi Test Stubs 1.0.0.M1" and passing mention on Eclipsepedia.
There appears to be only minor differences between the download from the blog and what appears to be the current source in git. I have not been able to build either with complaints of Cannot find .../virgo-build/multi-bundle/default.xml
So my questions are:
Is the test suite usable outside of the context of build Virgo?
The then how does one go about it? Is it necessary to build all of Virgo to acquire the bundle?
Many thanks,
Joel
]]>Joel Rosi-Schwartz2010-12-11T09:48:59-00:00Re: Availability and usage of osgi-test-stubs
https://www.eclipse.org/forums/index.php/mv/msg/201725/644439/#msg_644439
After reading the Virgo/Build instructions, building org.eclipse.virgo.teststubs.osgi.jar was a piece of cake.
Now I am interested in actually using it So my next port of call is to investigate the test cases in Virgo that use it.
Any advice or pointers on its usage would be quite appreciated.
Joel]]>Joel Rosi-Schwartz2010-12-11T10:12:02-00:00Re: Availability and usage of osgi-test-stubs
https://www.eclipse.org/forums/index.php/mv/msg/201725/644455/#msg_644455
Note I recently upgraded the test stubs to be compatible with Equinox 3.7 which takes into account generics. If you want an earlier version compatible with OSGi 4.2, checkout the 2.1.0.RELEASE tag of the test stubs repository.
Hope that gets you going.]]>Glyn Normington2010-12-11T16:37:44-00:00Re: Availability and usage of osgi-test-stubs
https://www.eclipse.org/forums/index.php/mv/msg/201725/644457/#msg_644457
Yes, I noticed the Equinox 3.7 when I did the diff between the SpringSource M1 release and the current Git version. I was wondering why, thanks for the heads up.
All the best,
Joel]]>Joel Rosi-Schwartz2010-12-11T17:09:25-00:00
