Eclipse Community ForumsWSDL + SOAP12 and Eclipse WSDL editor problem
https://www.eclipse.org/forums/index.php/mv/msg/201199/642531/#msg_642531
I'm trying to create some first contract web service by first realizing a WSDL with the WSDL editor coming along with eclipse. However it seams that :
It can't neither provide me with soap12 Biding
but also
do not support WSDL2
When I use the wsdl editor to inspect the WSDL file generated in code first appraoch from a SEI with as parameter of generation SOAP1.2 for the binding I always get this waring in the resulting WSDL:
"A description use neither MIME Biding as describre in WSDL 1.1 section 5 nor WSDL SOAP Biding in WSDL 1.1 section 3 on each of the WSDL:input and WSDL:output elements of WSDL:Binding "
Can someone help me, I would like to use WSDL 2 and SOAP 1.2]]>Maatari 2010-12-01T17:04:36-00:00Re: WSDL + SOAP12 and Eclipse WSDL editor problem
https://www.eclipse.org/forums/index.php/mv/msg/201199/642548/#msg_642548
Maatari 2010-12-01T18:24:42-00:00
