Eclipse Community ForumsMarketPlace didn't work with my RCP
https://www.eclipse.org/forums/index.php/mv/msg/201168/642409/#msg_642409
I am trying to integrate the Eclipse MarketPlace into my RCP program. I have added the "org.eclipse.epp.mpc.ui" dependency and copied org.eclipse.epp.mpc.*.jar into the Plugins folder. As the result I can launch the MarketPlace Wizard via the Help menu. But every time I got an "Unexpected Exception" when the Search/Recent/Popular tab opened.
Could anyone give me some advises to get the MarketPlace work with my RCP?
Stack trace:
at org.eclipse.jface.operation.ModalContext.run(ModalContext.ja va:421)
at org.eclipse.jface.wizard.WizardDialog.run(WizardDialog.java: 1008)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplaceViewer.do Query(MarketplaceViewer.java:237)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplaceViewer.do Query(MarketplaceViewer.java:229)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplaceViewer.se tContentType(MarketplaceViewer.java:328)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplacePage$1.wi dgetSelected(MarketplacePage.java:111)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListe ner.java:234)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:4066)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3657)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825 )
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.eclipse.epp.internal.mpc.ui.commands.MarketplaceWizardCo mmand.execute(MarketplaceWizardCommand.java:140)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(Handle rProxy.java:293)
at org.eclipse.core.commands.Command.executeWithChecks(Command. java:476)
at org.eclipse.core.commands.ParameterizedCommand.executeWithCh ecks(ParameterizedCommand.java:508)
at org.eclipse.ui.internal.handlers.HandlerService.executeComma nd(HandlerService.java:169)
at org.eclipse.ui.internal.handlers.SlaveHandlerService.execute Command(SlaveHandlerService.java:241)
at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSel ection(CommandContributionItem.java:820)
at org.eclipse.ui.menus.CommandContributionItem.access$19(Comma ndContributionItem.java:806)
at org.eclipse.ui.menus.CommandContributionItem$5.handleEvent(C ommandContributionItem.java:796)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2629)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2593)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:24 27)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:670)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:663)
at com.adobe.lcide.rcp.Application.start(Unknown Source)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:196)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 619)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
at org.eclipse.epp.internal.mpc.ui.catalog.MarketplaceDiscovery Strategy.handleSearchResult(MarketplaceDiscoveryStrategy.jav a:159)
at org.eclipse.epp.internal.mpc.ui.catalog.MarketplaceDiscovery Strategy.popular(MarketplaceDiscoveryStrategy.java:357)
at org.eclipse.epp.internal.mpc.ui.catalog.MarketplaceCatalog$3 .run(MarketplaceCatalog.java:86)
at org.eclipse.epp.internal.mpc.ui.catalog.MarketplaceCatalog.p erformDiscovery(MarketplaceCatalog.java:316)
at org.eclipse.epp.internal.mpc.ui.catalog.MarketplaceCatalog.p opular(MarketplaceCatalog.java:84)
at org.eclipse.epp.internal.mpc.ui.wizards.MarketplaceViewer$3. run(MarketplaceViewer.java:241)
at org.eclipse.jface.operation.ModalContext$ModalContextThread. run(ModalContext.java:121)
]]>No real name2010-12-01T08:57:46-00:00Re: MarketPlace didn't work with my RCP
https://www.eclipse.org/forums/index.php/mv/msg/201168/642588/#msg_642588
http://wiki.eclipse.org/Marketplace/REST]]>Ian Skerrett2010-12-01T21:21:37-00:00Re: MarketPlace didn't work with my RCP
https://www.eclipse.org/forums/index.php/mv/msg/201168/642618/#msg_642618
No real name2010-12-02T02:07:02-00:00Re: MarketPlace didn't work with my RCP
https://www.eclipse.org/forums/index.php/mv/msg/201168/642649/#msg_642649
Set knownRepositories = new HashSet(
Arrays.asList(repositoryTracker.getKnownRepositories(session)));
so repositoryTracker must be null. This variable was returned by ProvisioningUI:
