Eclipse Community Forumsproject dependency on antbuilder product
https://www.eclipse.org/forums/index.php/mv/msg/201149/642333/#msg_642333
To one project, under Builders, I added the ant builder above the jar builder.
However, the project will not run because the project sees a jar is missing that the jar builder depends on.
If the project would just run the ant builder, the jar would be created..
What are my options?
Do I create some type of project that only runs the ant builder, to create the jar that the jar builder depends on?
I would prefer a solution that would not remove the use of ant.]]>John Stile2010-11-30T20:02:51-00:00
