Eclipse Community Forums[Eugenia] internal error when using "synchronize GMF gen model" more than once
https://www.eclipse.org/forums/index.php/mv/msg/201123/642240/#msg_642240
i d/l the latest version of epsilon (0.9.0.201011251259), and while testing it i realized that the "synchronize GMF gen model" option on the .gmfgen model is causing an error when accidentally used more than once.
it does not have an effect on the model however (the .gmfgen is not damaged), but nevertheless i thought it might me interesting for you to know.
would have filed a bug report, but for some reason i couldn't find the eugenia component in bugzilla...
cheers
marco
ps: ok now that i took a closer look at the error message i know what's causing it. in my FixGMFGen.eol i remove an entry from a toolgroup.
so when this is called a second time, the entry is not found anymore -> error.
for some reason this error was suppressed (or not arising) in the version i was using before (0.8.0...).
dunno if this is a problem or not...
Internal error: java.lang.IllegalArgumentException
at sun.reflect.NativeMethodAccessorImpl.invoke0[Native Method]
at sun.reflect.NativeMethodAccessorImpl.invoke[Unknown Source]
at sun.reflect.DelegatingMethodAccessorImpl.invoke[Unknown Source]
at java.lang.reflect.Method.invoke[Unknown Source]
at org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod[Re flectionUtil.java:183]
at org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod[Re flectionUtil.java:164]
at org.eclipse.epsilon.eol.execute.PointExecutor.executeOperati on[PointExecutor.java:161]
at org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointE xecutor.java:74]
at org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointE xecutor.java:42]
at org.eclipse.epsilon.eol.execute.PointExecutor.execute[PointE xecutor.java:130]
at org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST[E xecutorFactory.java:179]
at org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execu te[StatementBlockExecutor.java:33]
at org.eclipse.epsilon.eol.EolModule.execute[EolModule.java:57]
at org.eclipse.epsilon.eugenia.EugeniaActionDelegate.runImpl[Eu geniaActionDelegate.java:168]
at org.eclipse.epsilon.eugenia.EugeniaActionDelegate$1.run[Euge niaActionDelegate.java:81]
at org.eclipse.core.internal.jobs.Worker.run[Worker.java:55]
(D:\workspaces\workspace\de.fraunhofer.fokus.testing.fokusmb t.diagram.gmf.testpurpose\model\FixGMFGen.eol@86:66)
at org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod(Re flectionUtil.java:183)
at org.eclipse.epsilon.eol.util.ReflectionUtil.executeMethod(Re flectionUtil.java:164)
at org.eclipse.epsilon.eol.execute.PointExecutor.executeOperati on(PointExecutor.java:161)
at org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:74)
at org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:42)
at org.eclipse.epsilon.eol.execute.PointExecutor.execute(PointE xecutor.java:130)
at org.eclipse.epsilon.eol.execute.ExecutorFactory.executeAST(E xecutorFactory.java:179)
at org.eclipse.epsilon.eol.execute.StatementBlockExecutor.execu te(StatementBlockExecutor.java:33)
at org.eclipse.epsilon.eol.EolModule.execute(EolModule.java:57)
at org.eclipse.epsilon.eugenia.EugeniaActionDelegate.runImpl(Eu geniaActionDelegate.java:168)
at org.eclipse.epsilon.eugenia.EugeniaActionDelegate$1.run(Euge niaActionDelegate.java:81)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)]]>m kranz2010-11-30T14:21:35-00:00Re: [Eugenia] internal error when using "synchronize GMF gen model" more than once
https://www.eclipse.org/forums/index.php/mv/msg/201123/642337/#msg_642337
Thanks for reporting this. Epsilon is already a component (of GMT) and
the bugzilla doesn't support components of components. Therefore, all
bugs should just be reported under Epsilon. Could you please file a bug
report and we'll sort this out in the next interim release.
Dimitris
On 30/11/2010 15:21, mkranz wrote:
> hi dimitri
> know.
> eugenia component in bugzilla... :?
> cheers
> marco
> GmfGen!ToolGroup.all.selectOne(r|r.title =
> 'Connections').entries.remove(GmfGen!ToolEntry.all.selectOne (r|r.title
> = 'RealizedTestPurpose'));
> error.
> xecutor.java:74]
> xecutor.java:42]
> xecutor.java:130]
> t.diagram.gmf.testpurpose\model\mailto:FixGMFGen.eol@86:66)
> xecutor.java:74)
> xecutor.java:42)
> xecutor.java:130)
> at org.eclipse.core.internal.jobs.Worker.run(Worker.java:55)]]>Dimitrios Kolovos2010-11-30T20:31:52-00:00Re: [Eugenia] internal error when using "synchronize GMF gen model" more than once
https://www.eclipse.org/forums/index.php/mv/msg/201123/642441/#msg_642441
]]>m kranz2010-12-01T11:19:58-00:00
