Eclipse Community Forumseclipse locks up on egit commit
https://www.eclipse.org/forums/index.php/mv/msg/201086/642105/#msg_642105
I've set up the user name and email in the prefs.
I've successfully added my existing project to a new repository.
I made changes to a couple files and saved them, sure enough the little greater than showed up immediately. So far so good...but
For some reason when I select Team->Commit on a file in the navigation pane eclipse locks up. I'm assuming I should be getting some sort of pop-up window.
I ran the Update checker, it updated a few things, but the problems still persists.
I'm running Gallileo build 20100218-1602 and egit 0.9.3
I'm kinda stuck as to where to look now. doing some googling, but nothing obvious seems to come up. I'm sure this is just something due to my ignorance on the topic, as I said, I'm new to this.
any help is appreciated.
]]>justin 2010-11-29T20:48:06-00:00Re: eclipse locks up on egit commit
https://www.eclipse.org/forums/index.php/mv/msg/201086/642121/#msg_642121
Add that stack trace to a new bug report at bugs.eclipse.org. If you have a very small project and it contains no secrets you could zip it up and attach that too to the bug report.
]]>Robin Rosenberg2010-11-29T23:07:32-00:00Re: eclipse locks up on egit commit
https://www.eclipse.org/forums/index.php/mv/msg/201086/642124/#msg_642124
justin 2010-11-29T23:56:44-00:00Re: eclipse locks up on egit commit
https://www.eclipse.org/forums/index.php/mv/msg/201086/642320/#msg_642320
Here is the trace dump, I'm posting it here because at the moment I'm not sure this is a bug or just something I'm doing due to noob status. From what I've read Git is one of the preffered methods of version tracking, but I can't believe that I'm bringing it to it's knees with my set of files. I can't seem to find a way of it telling me how many files it's tracking or their overall size, I would guess something like just under 100 files, however they are in a project that contains probably over 50,000 (lots of assets and images that don't need version control, I really just want it for the code)
2010-11-30 10:47:18
Full thread dump Java HotSpot(TM) Client VM (17.1-b03 mixed mode, sharing):
"Worker-11" prio=6 tid=0x02d8c400 nid=0x104 in Object.wait() [0x0465f000]
java.lang.Thread.State: TIMED_WAITING (on object monitor)
at java.lang.Object.wait(Native Method)
at org.eclipse.core.internal.jobs.WorkerPool.sleep(WorkerPool.j ava:185)
- locked <0x1c0b2fc8> (a org.eclipse.core.internal.jobs.WorkerPool)
at org.eclipse.core.internal.jobs.WorkerPool.startJob(WorkerPoo l.java:217)
at org.eclipse.core.internal.jobs.Worker.run(Worker.java:51)
Locked ownable synchronizers:
- None
"Worker-9" prio=6 tid=0x10457400 nid=0xa74 in Object.wait() [0x0f14f000]
- None
"JavaScript indexing" daemon prio=4 tid=0x05601400 nid=0xe4 in Object.wait() [0x06b7f000]
java.lang.Thread.State: WAITING (on object monitor)
- waiting on <0x2087ccb8> (a org.eclipse.wst.jsdt.internal.core.search.indexing.IndexMana ger)
at java.lang.Object.wait(Object.java:485)
at org.eclipse.wst.jsdt.internal.core.search.processing.JobMana ger.run(JobManager.java:370)
- locked <0x2087ccb8> (a org.eclipse.wst.jsdt.internal.core.search.indexing.IndexMana ger)
- None
"[ThreadPool Manager] - Idle Thread" daemon prio=6 tid=0x03e96400 nid=0x148 in Object.wait() [0x0714f000]
at org.eclipse.equinox.internal.util.impl.tpt.threadpool.Execut or.run(Executor.java:106)
- locked <0x1fb13558> (a org.eclipse.equinox.internal.util.impl.tpt.threadpool.Execut or)
- None
"Java indexing" daemon prio=4 tid=0x03fb5c00 nid=0x5f0 in Object.wait() [0x06e7f000]
- waiting on <0x1f927d18> (a org.eclipse.jdt.internal.core.search.indexing.IndexManager)
at org.eclipse.jdt.internal.core.search.processing.JobManager.r un(JobManager.java:381)
- locked <0x1f927d18> (a org.eclipse.jdt.internal.core.search.indexing.IndexManager)
- None
"PHP Debugger Daemon Thread - Port: 9000" daemon prio=6 tid=0x03ee2c00 nid=0xa14 runnable [0x06d7f000]
java.lang.Thread.State: RUNNABLE
at java.net.PlainSocketImpl.socketAccept(Native Method)
at java.net.PlainSocketImpl.accept(Unknown Source)
- locked <0x1f84a5e0> (a java.net.SocksSocketImpl)
at java.net.ServerSocket.implAccept(Unknown Source)
at java.net.ServerSocket.accept(Unknown Source)
at org.eclipse.php.internal.debug.core.daemon.AbstractDebuggerC ommunicationDaemon$ReceiverThread.run(AbstractDebuggerCommun icationDaemon.java:185)
- None
"PHP Debugger Daemon Thread - Port: 10000" daemon prio=6 tid=0x0500f000 nid=0xa1c runnable [0x06a7f000]
- locked <0x1f84a7c8> (a java.net.SocksSocketImpl)
- None
"DLTK indexing" daemon prio=4 tid=0x035cf000 nid=0x85c in Object.wait() [0x0697f000]
- waiting on <0x1f6fb928> (a org.eclipse.dltk.core.search.indexing.IndexManager)
at org.eclipse.dltk.internal.core.search.processing.JobManager. run(JobManager.java:426)
- locked <0x1f6fb928> (a org.eclipse.dltk.core.search.indexing.IndexManager)
- None
"net.sourceforge.phpdt.internal.ui.text.JavaReconciler" daemon prio=2 tid=0x050b2400 nid=0x17c in Object.wait() [0x061bf000]
at org.eclipse.jface.text.reconciler.AbstractReconciler$Backgro undThread.run(AbstractReconciler.java:179)
- locked <0x1f58c118> (a org.eclipse.jface.text.reconciler.DirtyRegionQueue)
- None
"Bundle File Closer" daemon prio=6 tid=0x05025c00 nid=0x204 in Object.wait() [0x05e0f000]
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .getNextEvent(EventManager.java:397)
- locked <0x1f273670> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
at org.eclipse.osgi.framework.eventmgr.EventManager$EventThread .run(EventManager.java:333)
- None
"[Timer] - Main Queue Handler" daemon prio=6 tid=0x03d25400 nid=0x95c in Object.wait() [0x0441f000]
at org.eclipse.equinox.internal.util.impl.tpt.timer.TimerImpl.r un(TimerImpl.java:141)
- locked <0x1c1c0710> (a java.lang.Object)
- None
"Provisioning Event Dispatcher" daemon prio=6 tid=0x03ccc400 nid=0xe48 in Object.wait() [0x0421f000]
- waiting on <0x1c0b2ed8> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- locked <0x1c0b2ed8> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- None
"Worker-0" prio=6 tid=0x03c8d400 nid=0x9d8 waiting on condition [0x0411f000]
java.lang.Thread.State: WAITING (parking)
at sun.misc.Unsafe.park(Native Method)
- parking to wait for <0x1f7fb528> (a java.util.concurrent.locks.AbstractQueuedSynchronizer$Condit ionObject)
at java.util.concurrent.locks.LockSupport.park(Unknown Source)
at java.util.concurrent.locks.AbstractQueuedSynchronizer$Condit ionObject.await(Unknown Source)
at java.util.concurrent.LinkedBlockingQueue.take(Unknown Source)
at org.eclipse.epp.usagedata.internal.gathering.services.UsageD ataService.getQueuedEvent(UsageDataService.java:221)
at org.eclipse.epp.usagedata.internal.gathering.services.UsageD ataService.access$0(UsageDataService.java:219)
at org.eclipse.epp.usagedata.internal.gathering.services.UsageD ataService$1.run(UsageDataService.java:157)
- None
"Framework Event Dispatcher" daemon prio=6 tid=0x03627800 nid=0x98c in Object.wait() [0x03b7f000]
- locked <0x1bf87308> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- None
"Start Level Event Dispatcher" daemon prio=6 tid=0x0361d400 nid=0x784 in Object.wait() [0x03a7f000]
- waiting on <0x1bf87380> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- locked <0x1bf87380> (a org.eclipse.osgi.framework.eventmgr.EventManager$EventThread )
- None
"State Data Manager" daemon prio=6 tid=0x03631400 nid=0xca8 waiting on condition [0x0397f000]
java.lang.Thread.State: TIMED_WAITING (sleeping)
at java.lang.Thread.sleep(Native Method)
at org.eclipse.osgi.internal.baseadaptor.StateManager.run(State Manager.java:306)
"Finalizer" daemon prio=8 tid=0x02cbcc00 nid=0x35c in Object.wait() [0x0309f000]
at java.lang.ref.ReferenceQueue.remove(Unknown Source)
- locked <0x1bee0318> (a java.lang.ref.ReferenceQueue$Lock)
at java.lang.ref.Finalizer$FinalizerThread.run(Unknown Source)
- None
"Reference Handler" daemon prio=10 tid=0x02cbb400 nid=0xf50 in Object.wait() [0x02f9f000]
at java.lang.ref.Reference$ReferenceHandler.run(Unknown Source)
- locked <0x1bee03a8> (a java.lang.ref.Reference$Lock)
- None
"main" prio=6 tid=0x009c6800 nid=0x944 runnable [0x0013e000]
at java.util.ArrayList.indexOf(Unknown Source)
at java.util.ArrayList.contains(Unknown Source)
at org.eclipse.egit.ui.internal.actions.CommitActionHandler.inc ludeList(CommitActionHandler.java:324)
at org.eclipse.egit.ui.internal.actions.CommitActionHandler.bui ldIndexHeadDiffList(CommitActionHandler.java:304)
at org.eclipse.egit.ui.internal.actions.CommitActionHandler.exe cute(CommitActionHandler.java:89)
at org.eclipse.egit.ui.internal.actions.RepositoryAction.run(Re positoryAction.java:77)
at org.eclipse.ui.internal.PluginAction.runWithEvent(PluginActi on.java:251)
at org.eclipse.jface.action.ActionContributionItem.handleWidget Selection(ActionContributionItem.java:584)
at org.eclipse.jface.action.ActionContributionItem.access$2(Act ionContributionItem.java:501)
at org.eclipse.jface.action.ActionContributionItem$5.handleEven t(ActionContributionItem.java:411)
at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java :84)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1003)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.ja va:3910)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java :3503)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.jav a:2405)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2369)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:22 21)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:500)
at org.eclipse.core.databinding.observable.Realm.runWithDefault (Realm.java:332)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Work bench.java:493)
at org.eclipse.ui.internal.ide.application.IDEApplication.start (IDEApplication.java:113)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(Eclips eAppHandle.java:194)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .runApplication(EclipseAppLauncher.java:110)
at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher .start(EclipseAppLauncher.java:79)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:368)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseS tarter.java:179)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java: 559)
You could try the nightly build to see if there is any improvement but the above bug is still open.]]>Bernard Leach2010-12-06T02:54:40-00:00Re: eclipse locks up on egit commit
https://www.eclipse.org/forums/index.php/mv/msg/201086/643212/#msg_643212
I'll have to either keep an eye on that bug or use something else for the time being. Thanks!]]>justin 2010-12-06T03:44:02-00:00
