Eclipse Community ForumsProblems setting EGit with github
https://www.eclipse.org/forums/index.php/mv/msg/200890/641439/#msg_641439
I'm a new user of git/github/egit.
I've had the chance of cloning projects from github before, but now I've forked a project to my own repository and I want to work on it in eclipse.
Unfortunately, I've been having a hard time configuring egit, and I can't figure out what I'm doing wrong.
General info:
- Eclipse 3.6.1
- Egit version - latest nightly (have tried with latest stable as well)
- OS: Fedora 13
What I've done so far successfully:
- Created a remote repository pointing to the github repository using https, and managed to fetch everything.
- Create a private and public keys from cli, uploaded the public key to github, and did the ssh test successfully, plus managed to fetch from cli.
- Create a private and public keys from eclipse, uploaded the public key to github, did the cli experiments, all work well.
(*) all generated keys uses a pass phrase.
What I've tried doing, with no luck:
- When configuring the remote repository using https, pushing doesn't work.
- When configuring the remote repository using ssh, fetching and pushing doesn't work. I get 'Auth error', and it doesn't even ask me for the pass phrase (as it should according to various tutorials on the web).
What the tutorials say and I can't do:
- Many tutorials on the web state that the protocol to be used should be git+ssh. Even egit's official user guide says to use it. Unfortunately, the latest stable build and the latest nightly don't have that option anymore.
I'd really appreciate any suggestions on how to move forward. I've been tinkering with it for about two days, with not much luck so far.
Ron]]>Ron Missing name2010-11-25T13:34:46-00:00Re: Problems setting EGit with github
https://www.eclipse.org/forums/index.php/mv/msg/200890/641460/#msg_641460
We renamed "git+ssh:" to "ssh:" since this confused users and all other git tools use "ssh:". EGit should still support "git+ssh:" but you have to manually type this in in the URI field, this value is not in the combo box anymore. Technically there is no difference.
Did you try our tiny Github tutorial in the EGit user guide [1] ?
[1] http://wiki.eclipse.org/EGit/User_Guide#Github_Tutorial
]]>Matthias Sohn2010-11-25T15:12:56-00:00Re: Problems setting EGit with github
https://www.eclipse.org/forums/index.php/mv/msg/200890/641474/#msg_641474
I did try the tutorial you've mentioned, and it just doesn't work.
Unfortunately, the tutorial is outdated on at least two points:
1. github's interface has changed
2. as mentioned before, git+ssh doesn't exist anymore (I understand the change you've made, but the fact that it's still in the tutorial is confusing).
What I get after I define the push repository, is the "Push Ref Specifications" window, grayed out, and a few moments after that I get an error popup with 'Auth failed' message.
I don't get the fingerprint message, since I've already accepted it before from cli, and I don't get the passphrase window even though my keys have it.
Any other suggestions? I have a feeling I'm missing something trivial, I just can't find out what.]]>Ron Missing name2010-11-25T15:35:56-00:00Re: Problems setting EGit with github
https://www.eclipse.org/forums/index.php/mv/msg/200890/642197/#msg_642197
Ron Missing name2010-11-30T11:02:13-00:00Re: Problems setting EGit with github
https://www.eclipse.org/forums/index.php/mv/msg/200890/643651/#msg_643651
I can easily push from command line using: git push origin master
That works perfectly, and is the workaround I'm using instead of pushing via EGit's interface. Which I can't get to work.
I've found a few others reporting the same problems, like this thread. But no solution. Is there any new solution yet?]]>VIBrunazo 2010-12-07T18:25:04-00:00Re: Problems setting EGit with github
https://www.eclipse.org/forums/index.php/mv/msg/200890/648898/#msg_648898
I have helios service release 1 (build id 20100917-0705) with pydev and egit just updated today on a Windows Vista machine. I have a free github account with a repository created there.
1. I made a pydev project, put it under Git revision control, added and committed two files. That seems to work fine.
2. In Windows > Preferences > Network Connections > SSH2 I have SSH2 Home at: C:\Users\<username>\ssh and these private keys: id_dsa,id_rsa.
In the key management tab I have clicked Generate RSA Key, filled in passphrase and confirmation, saved the private key, and copied the public key and installed at github.
3. In the Git menu, I selected push and filled in the remote repository information as follows:
URI: git+ssh://git@github.com/Name/Repo.git
Host: github.com
Repo path: /Name/Repo.git
Protocol: ssh (git+ssh is not longer an option)
port: empty
user: git
password: empty
store in secure store: checked
When I hit Next I get the Push Ref Specs dialog and this error message:
The URIs with colons seem to give trouble in the dialog, though I have seen people recommend to try this for read-only github repositories. However I don't think this is the problem since I have put the repository in SSH mode at github.
Any ideas? Does anyone have this working (pydev + egit + github)? If there is not a fix is there a recommended workaround? Any ideas to diagnose the problem more clearly? Does anyone have a really detailed description for getting this working?
Thanks!
Melissa]]>Melissa Rice2011-01-15T05:38:59-00:00Re: Problems setting EGit with github
https://www.eclipse.org/forums/index.php/mv/msg/200890/648902/#msg_648902
I read a post which suggested these fields but the autofill in the dialog prevents this from being entered because each time you edit one field, it changes another one....
I also checked the documentation at github but they don't support egit, unfortunately.
Thanks, in advance, for any ideas.
Melissa]]>Melissa Rice2011-01-15T06:29:02-00:00Re: Problems setting EGit with github [solved]
https://www.eclipse.org/forums/index.php/mv/msg/200890/648905/#msg_648905
1. Set up the ssh key stuff
a. Download and install mysys git according to the github instructions at http://help.github.com/win-git-installation/
b. In C:/Users/you/ssh hide any existing keys (id_rsa and id_rsa.pub) in a subdirectory. If the ssh directory does not exist, create it. Of course, "you" is your username as the OS knows you.
c. From the start menu, run Git-Bash command shell (a regular DOS command shell will not work).
d. In the Git-Bash shell generate an rsa key based on your email (the one you registered at github):
ssh-keygen -t rsa -C "you@wherever.com"
and enter your pass phrase and confirm when asked.
e. The previous step should have created C:/User/you/ssh/id_rsa.pub which you can now open in a text editor and copy. At github, go to account settings, SSH Keys, add a key and paste this in the key box.
f. In Git-Bash again (notice the back-ticks in the next line):
eval `ssh-agent`
ssh-add C:/User/you/ssh/id_rsa
ssh git@github.com
Here is what you just did: you ran the ssh-agent which is needed by ssh-add. Then you used ssh-add to make note of the location of your key. Then you tried to ssh to git hub. The response to this last command should be that you have successfully authenticated at github but that you don't have shell access. This is just an authentication test. If the authentication was not successful you'll have to sort that out. Try the verbose version: ssh -v git@github.com
Assuming this worked....
2. In eclipse, configure the remote push
a. Window > Show View > Git > Git Repositories will add a repository explorer window.
b. In the repository window, select the repository and expand and right-click Remotes and choose Create Remote.
c. Copy the github repository URI from the github repository page and paste this in the URI box.
d. Select ssh as the protocol but then go back to the URI box and add "git+" at the beginning so it looks like this: git+ssh://git@github.com/UserName/ProjectName.git
e. In the Repository Path box, remove the leading slash
f. Hit next and cross your fingers. If your get "auth fail" restart eclipse and try step 5 again.
g. When you get past the authentication, in the next dialog select "master" for source ref, click "Add all branches spec" and "Finish".
Now try a push to github. This worked for me but with all the fiddling around I'm not sure these instructions are perfect....
Why don't you just copy the URI from the github page and paste it into the EGit URI field, this works both with ssh and https protocol for me.
(msohn is my github user id). If you are still on EGit 0.9 you should upgrade to 0.10.
To keep things simple you may use the same ssh keys from EGit and msysgit, just point them to the same folder. (On Windows the Eclipse ssh configuration points to ~/ssh instead of ~/.ssh used by msysgit, correct this by changing the path in Eclipse preferences).
You do not need to add git+ in front of ssh, we removed that because nobody else is using this URI scheme form (it's still accepted but no longer used by the combo).]]>Matthias Sohn2011-01-20T22:09:34-00:00Re: Problems setting EGit with github [solved]
https://www.eclipse.org/forums/index.php/mv/msg/200890/650652/#msg_650652
I'm not sure whether your reply was directed to Melissa or to me.
Just a few points:
1. For me, the issue was solved a couple of weeks ago upon upgrading the latest nightly without me changing anything in the configuration. It most certainly didn't work with the nightly build when I originally made the post.
2. It's obvious that you've updated the EGit manual to comply both with github's changes and EGit's changes. Again, when you originally replied, it wasn't updated.
While I'm sorry the response took a while, I do appreciate the work you're doing on the plug-in and the constant effort you put into it.
Ron]]>Ron Missing name2011-01-25T20:43:47-00:00Re: Problems setting EGit with github
https://www.eclipse.org/forums/index.php/mv/msg/200890/655388/#msg_655388
I too had a problem with Egit, Github and SSH. I followed the push instructions in the tutorial. After entering in the url and clicking 'next' a pop-up would come up with 'username: git' ; 'passphrase: '. There didn't seem to be any passphrase entry that would satisfy it and would continue to pop up after clicking 'ok'. Didn't work for either ssh:// or git+ssh://
I tried it on Galileo and Helios. Egit is 0.11.1. Running Ubuntu 10.10.
I have everything working through https but just wanted to mention it. If there is a way to fix it, feel free to drop me a reply ]]>Padraic Harley2011-02-20T11:11:19-00:00Re: Problems setting EGit with github
https://www.eclipse.org/forums/index.php/mv/msg/200890/655424/#msg_655424
I'm not an expert at git or ssh keys, but I'm happy to tell you what worked for me, which is to install mysysgit (I'm on a Windows Vista platform) and carefully follow the instructions for setting up the ssh key. This is probably not the most direct method, but it worked for me.
Here is specifically what I did:
1. Download and install mysys git according to the github instructions at http://help.github.com/win-git-installation/
2. In C:/Users/you/ssh hide any existing keys (id_rsa and id_rsa.pub) in a subdirectory. If the ssh directory does not exist, create it. Of course, "you" is your username as the OS knows you.
3. From the start menu, run Git-Bash command shell (a regular DOS command shell will not work).
4. In the Git-Bash shell generate an rsa key based on your email (the one you registered at github):
and enter your passphrase and confirm when asked.
5. The previous step should have created C:/User/you/ssh/id_rsa.pub which you can now open in a text editor and copy.
6. At github, go to account settings, SSH Keys, add a key and paste the key text from your paste buffer into the key box.
7. In Git-Bash again (notice the back-ticks in the next line):
Good luck,
Melissa
]]>Melissa Rice2011-02-20T19:17:51-00:00Re: Problems setting EGit with github [solved]
https://www.eclipse.org/forums/index.php/mv/msg/200890/655425/#msg_655425
Thanks very much for you reply. Sorry for the delay in my response.
I did follow the tutorial (some version at least) and found it mostly very thorough and well-written - Thank You.
The problem turned out to be with the key, for which there was little information in the version of the tutorial I was reading. I resolved the problem by following the more comprehensive instructions with mysysgit. I'm quite busy with a project right now but sometime in the next couple months I hope to carve out more time to install eGit on another machine, at which point I will try following the instructions you point to and will let you know what part, if any, is unclear or not working as expected.
The root problem is undoubtedly that I am new to eclipse, git, and ssh-keys.
Thanks again for your thoughtful response and for taking the time to write the tutorial. Much appreciated.
Melissa]]>Melissa Rice2011-02-20T19:20:59-00:00Re: Problems setting EGit with github
https://www.eclipse.org/forums/index.php/mv/msg/200890/665168/#msg_665168
Andy]]>Andy 2011-04-13T14:34:13-00:00Re: Problems setting EGit with github
https://www.eclipse.org/forums/index.php/mv/msg/200890/673987/#msg_673987
PULL
PUSH
You have to configure the PUSH URI.
EGIT adds a (nonsense?) port to the SSH URI.
Remove the port and add "git+" in front of the URI.
This fixes "connection refused".
This fix is not proven for "auth fail".
I fixed "auth fail" by avoiding whitespace artifacts while copy pasting the key from Eclipse into GitHub (any hoster).
(Assembla has problems with processing key files created under Windows by using PuTTyGen).]]>Julius Foitzik2011-05-25T12:28:21-00:00Re: Problems setting EGit with github
https://www.eclipse.org/forums/index.php/mv/msg/200890/674425/#msg_674425
[1] https://bugs.eclipse.org/bugs/show_bug.cgi?id=346806]]>Matthias Sohn2011-05-26T21:22:56-00:00Re: Problems setting EGit with github
https://www.eclipse.org/forums/index.php/mv/msg/200890/722945/#msg_722945
Basically, follow Melissa's steps for installing msysgit, creating your keys, and configuring the push/pull remotes in your project's GIT Repo view.
Unlike Meilissa, I didn't have to mess with /'s on path names, or changing type to git+ssh, just copy the ssh URL from your github project and paste it.
If running on Windows, got to prefs, general, networking, ssh2 and make sure the default path is correct, it seems to default to ~/ssh instead of ~/.ssh.
But the real missing piece is ... create the file ~/.ssh/config, and put this in it:
Host github.com
HostName github.com
User git
PreferredAuthentications publickey
IdentityFile ~/.ssh/id_rsa
After which, when you try your 'dry run' you should finally get promoted for your ssh pass phrase, and it should connect with no problems.
-- hugh
]]>Hugh Messenger2011-09-07T09:30:18-00:00Re: Problems setting EGit with github
https://www.eclipse.org/forums/index.php/mv/msg/200890/1814854/#msg_1814854
Ron Missing name wrote on Thu, 25 November 2010 15:35
Thanks for the prompt reply.
I have one solution that can be useful, it works for me the maximum time. Just follow these steps: 1) right-click the conflict file 2) click on the replacement → head revision 3) wait several times (hold the patient, it will take time) 4) repeat all the previous steps for all conflict files]]>Edward Hobbs2019-09-20T11:11:23-00:00
