Eclipse Community Forumsdrill-through hyperlinks contain unwanted ../../..
https://www.eclipse.org/forums/index.php/mv/msg/200519/640071/#msg_640071
When I run this under eclipse it works correctly.
When I copy both .rptdocument files to the
$TOMCAT_HOME/webapps/WebViewerExample file, they work indendently, but the drill through is broken.
I do not know where the "../../.." is coming from. Without the "../../.." it works, but I can't figure out how to prevent "../../.." from getting inserted into my hyperlink.
Does anyone have any idea what might be causing this?
Thanks!!
]]>No real name2010-11-18T22:21:04-00:00Re: drill-through hyperlinks contain unwanted ../../..
https://www.eclipse.org/forums/index.php/mv/msg/200519/640207/#msg_640207
Jason
On 11/18/2010 5:21 PM, rhinmass@yahoo.com wrote:
> I created a pie chart and a detail chart. I configured the pie chart to
> drill through to the detail chart. I saved them both as .rptdocument in
> the project directory.
> The message I get is:
> org.eclipse.birt.report.exception.ViewerException: Cannot access the
> document file : C:\Apache Software Foundation\Tomcat
> 6.0\webapps\WebViewerExample/../../../detail.rptdocument.
> Thanks!!
>]]>Jason Weathersby2010-11-19T15:07:10-00:00Re: drill-through hyperlinks contain unwanted ../../..
https://www.eclipse.org/forums/index.php/mv/msg/200519/640246/#msg_640246
I'm new to this group and can't seem to figure out how to upload my files.
Here are the recreate steps.
1. For dataset use flat csv file:
item,color
apple,red
fire truck,red
sky,blue
sun,yellow
banana,yellow
grass,green
money,green
envy,green
rash,red
violet,blue
rose,red
smurf,blue
lime,green
avocado,green
2. Create color_detail.rptdesign, from this data set. I just dragged the dataset onto the layout; previewed and saved.
3. Under Run menu, click on generate document and save it in the project folder alongside the rptdesign file.
4. Create new report pie.rptdesign with same data set above.
5. Create pie chart. For slice size definition use COUNT row["item"]. For category use row["color"]
6. Click "Finish" ; save report .
7. Edit the pie chart and go to Format Chart; Series; Value Series; Interactivity
8. Choose Action Hyperlink, then add "color detail"; Edit Base URL; drill-through; Choose Report Document and navigate to the document file generated in step 3.
9. click OK; save the report and test it to make sure the drill-through works (ie when click on pie chart , the detail report pops up.)
10. Generate the pie.rptdocument as done in step 3.
11. Copy both pie.rptdocument and color_detail.rptdocument to the $TOMCATHOME/webapps/WebViewerExample folder
]]>No real name2010-11-19T18:22:10-00:00Re: drill-through hyperlinks contain unwanted ../../..
https://www.eclipse.org/forums/index.php/mv/msg/200519/640261/#msg_640261
or just email the files to me at jasonweathersby at windstream dot net.
Jason
On 11/19/2010 1:22 PM, rhinmass@yahoo.com wrote:
> I am using 2.6.1
> item,color
> apple,red
> fire truck,red
> sky,blue
> sun,yellow
> banana,yellow
> grass,green
> money,green
> envy,green
> rash,red
> violet,blue
> rose,red
> smurf,blue
> lime,green
> avocado,green
> Interactivity
> 12. View the pie in webbrowser:
> http://localhost:8080/WebViewerExample/frameset?__document=p ie.rptdocument
> 13. Click on the pie chart. The error message appears:
> Cannot access the document file : C:\Apache Software Foundation\Tomcat
> 6.0\webapps\WebViewerExample/../../../color_detail.rptdocume nt.
> Note that removing the "../../../" in the above link yields the detail
> chart.
> 14. Also I noticed that if I copy pie.rptdesign into the
> webapps/WebViewerExample folder and view it using the URL:
> http://localhost:8080/WebViewerExample/frameset?__report=pie .rptdesign,
> the drill-through does work correctly.
>]]>Jason Weathersby2010-11-19T19:02:53-00:00Re: drill-through hyperlinks contain unwanted ../../..
https://www.eclipse.org/forums/index.php/mv/msg/200519/640264/#msg_640264
__document=c:/temp/myrptdocument to generate the documents?
Jason
> I am using 2.6.1
> item,color
> apple,red
> fire truck,red
> sky,blue
> sun,yellow
> banana,yellow
> grass,green
> money,green
> envy,green
> rash,red
> violet,blue
> rose,red
> smurf,blue
> lime,green
> avocado,green
> Interactivity
> chart.
>]]>Jason Weathersby2010-11-19T19:23:43-00:00Re: drill-through hyperlinks contain unwanted ../../..
https://www.eclipse.org/forums/index.php/mv/msg/200519/640277/#msg_640277
I'm not sure I understand what this is supposed to do. I added &__document=c:/temp/myrptdocument to the URL:
Cannot access the document file : c:/temp/myrptdocument.
org.eclipse.birt.report.exception.ViewerException: Cannot access the document file : c:/temp/myrptdocument.
I do have a C:\temp folder , but rptdocument files in it.
[quote title=Jason Weathersby wrote on Fri, 19 November 2010 14:23]Can you try deploying both reports and then use the
Jason
]]>No real name2010-11-19T21:12:58-00:00Re: drill-through hyperlinks contain unwanted ../../..
https://www.eclipse.org/forums/index.php/mv/msg/200519/640281/#msg_640281
generate the rptdocument in the designer it is using the hyperlink that
was created there. Using __document in the viewer url should create the
rptdocument in the viewer. Just make sure to specify a __report and a
__document. You can then re-run your previous test with the newly
created documents.
Jason
On 11/19/2010 4:12 PM, rhinmass@yahoo.com wrote:
> Hi Jason,
> http://localhost:8080/WebViewerExample/frameset?__report=pie .rptdesign&__document=c:/temp/myrptdocument
> and got:
> Jason
>]]>Jason Weathersby2010-11-19T21:43:36-00:00Re: drill-through hyperlinks contain unwanted ../../..
https://www.eclipse.org/forums/index.php/mv/msg/200519/640287/#msg_640287
hmm... My goal is to be able to pregenerate the pie chart and detail reports corresponding to each sector each night from a cron job, because the real detail queries have several seconds latency. However, as it is I don't think it will work. Even if I manually place the pie report three levels down:
Where pie.rptdocument is pregenerated and deployed with the design?
Jason
On 11/19/2010 7:50 PM, rhinmass@yahoo.com wrote:
> OK, I think I see what is going on. The intermediate report is under
> WebViewerExample/documents/long-dir-name/long-dir-name/WebVi
> ewerExample/pie.rptdocument.
> three levels down:
> http://localhost:8080/WebViewerExample/frameset?__document=d ocuments\A\B\WebViewerExample\pie.rptdocument
> I get the same error when I click on the pie:
> Do you know of anyway to pregenerate the documents and have them link
> correctly?
> Thanks for any help.]]>Jason Weathersby2010-11-22T15:42:15-00:00Re: drill-through hyperlinks contain unwanted ../../..
https://www.eclipse.org/forums/index.php/mv/msg/200519/640645/#msg_640645
]]>No real name2010-11-22T16:53:47-00:00
