Eclipse Community ForumsError: <unused> is not recognized! by using version 2.6.1
https://www.eclipse.org/forums/index.php/mv/msg/200497/639990/#msg_639990
by runing birt report with version 2.6.1 i got following message during methode "validateParameters()" of "IRunAndRenderTask":
line 1 column 1 - Error: <unused> is not recognized!
This document has errors that must be fixed before
using HTML Tidy to generate a tidied up version.
i have checkt the reporting parameters, all of these were set correctly before start reporting generation. I am not sure where the said <unused> tag was generated. In the design xml there is no such tag at all.
Does anyone has idea how it does happen?
regards
]]>Peng 2010-11-18T15:46:52-00:00Re: Error: <unused> is not recognized! by using version 2.6.1
https://www.eclipse.org/forums/index.php/mv/msg/200497/639997/#msg_639997
Jason
On 11/18/2010 10:46 AM, Peng wrote:
> regards]]>Jason Weathersby2010-11-18T15:56:00-00:00Re: Error: <unused> is not recognized! by using version 2.6.1
https://www.eclipse.org/forums/index.php/mv/msg/200497/640006/#msg_640006
the report runs. the wished pdf was correct generated.
I get this type of error on all reports.
BTW: i just find out that this error has nothing to do with validetaParameters() methode. By comment this methode i still get the same error message.
Thanks for your help.
regards]]>Peng 2010-11-18T16:20:29-00:00Re: Error: <unused> is not recognized! by using version 2.6.1
https://www.eclipse.org/forums/index.php/mv/msg/200497/640012/#msg_640012
Jason
On 11/18/2010 11:20 AM, Peng wrote:
> Hi Jason,
> same error message.
> regards]]>Jason Weathersby2010-11-18T16:28:59-00:00Re: Error: <unused> is not recognized! by using version 2.6.1
https://www.eclipse.org/forums/index.php/mv/msg/200497/640125/#msg_640125
by setting the log level to FINEST i got the following log-content from the file "ReportEngine_2010_11_19_09_47_20.log" (i still can not any <unused> within it):
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.PreparedDataSourceQuery PreparedDataSourceQuery
FEINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineImpl@248fa53org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f0908org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@25287d8 {Report_Engine=org.eclipse.birt.report.engine.api.ReportEngine@3fd1ad2, Report_Design=org.eclipse.birt.report.engine.api.impl.ReportRunnable@20c93ce, servletResponse=null, Report_Design_File=DSReport, reportTask=null, servletRequest=null, Birt_Report_Parameters={ID=900505913 / 1, USER=Li, Peng 101}, org.eclipse.datatools.con]]>Peng 2010-11-19T09:08:53-00:00Re: Error: <unused> is not recognized! by using version 2.6.1
https://www.eclipse.org/forums/index.php/mv/msg/200497/640127/#msg_640127
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.PreparedQuery PreparedQuery
FEIN: PreparedQuery starts up.
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.aggregation.AggregateTable AggregateTable
FEINER: ENTRY
FEINER: RETURN
FEINER: ENTRY C:\Users\li2\AppData\Local\Temp\DataEngine_38337107_1\ [object Object] []
FEINER: RETURN
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.PreparedQuery <init>
FEIN: Start to prepare a PreparedQuery.
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.aggregation.AggrRegistry AggrRegistry
FEINER: ENTRY 0 -1 true org.eclipse.birt.core.script.ScriptContext@38341e2
FEINER: RETURN
19.11.2010 09:53:24 org.eclipse.birt.data.engine.expression.ColumnReferenceExpre ssion ColumnReferenceExpression
FEINER: ENTRY PART_NAME
FEINER: RETURN
FEINER: ENTRY PART_NUMBER
FEINER: RETURN
FEINER: ENTRY ID_VERSION
FEINER: RETURN
FEINER: ENTRY QUANTITY
FEINER: RETURN
FEINER: ENTRY MASS
FEINER: RETURN
FEINER: ENTRY PORTION
FEINER: RETURN
FEINER: ENTRY PORTION_INTERVAL
FEINER: RETURN
FEINER: ENTRY CLASS_NAME
FEINER: RETURN
FEINER: ENTRY APPLICATION_NAME_ID
FEINER: RETURN
FEINER: ENTRY PART_NAME_IMAGE
FEINER: RETURN
FEINER: ENTRY PART_NUMBER_IMAGE
FEINER: RETURN
FEINER: ENTRY CLASS_IMAGE
FEINER: RETURN
FEINER: ENTRY APPLICATION_IMAGE
FEINER: RETURN
FEINER: ENTRY LEVEL
FEINER: RETURN
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.GroupBindingColumn GroupBindingColumn
FEINER: ENTRY null 0 {PORTION=org.eclipse.birt.data.engine.api.querydefn.Binding@136c2fc7, CLASS_NAME=org.eclipse.birt.data.engine.api.querydefn.Binding@d5c9112, PART_NAME_IMAGE=org.eclipse.birt.data.engine.api.querydefn.Binding@d5d04653, APPLICATION_IMAGE=org.eclipse.birt.data.engine.api.querydefn.Binding@3291096c, PART_NAME=org.eclipse.birt.data.engine.api.querydefn.Binding@3c044f57, LEVEL=org.eclipse.birt.data.engine.api.querydefn.Binding@44fa364, PART_NUMBER=org.eclipse.birt.data.engine.api.querydefn.Binding@4d47a915, APPLICATION_NAME_ID=org.eclipse.birt.data.engine.api.querydefn.Binding@c721fb40, CLASS_IMAGE=org.eclipse.birt.data.engine.api.querydefn.Binding@9df46394, PORTION_INTERVAL=org.eclipse.birt.data.engine.api.querydefn.Binding@bcfaa63d, MASS=org.eclipse.birt.data.engine.api.querydefn.Binding@23fef4, QUANTITY=org.eclipse.birt.data.engine.api.querydefn.Binding@e20e548b, ID_VERSION=org.eclipse.birt.data.engine.api.querydefn.Binding@d76f0d94, PART_NUMBER_IMAGE=org.eclipse.birt.data.engine.api.querydefn.Binding@f64cd991}
FEINER: RETURN
FEIN: Finished preparing the PreparedQuery.
FEINER: RETURN
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery PreparedScriptDSQuery
FEINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineImpl@248fa53org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f1e04org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@253d837 {Report_Engine=org.eclipse.birt.report.engine.api.ReportEngine@3fd1ad2, Report_Design=org.eclipse.birt.report.engine.api.impl.ReportRunnable@20c93ce, servletResponse=null, Report_Design_File=DSReport, reportTask=null, servletRequest=null, Birt_Report_Parameters={ID=900505913 / 1, USER=Li, Peng 101}, org.eclipse.datatools.connectivity.oda.util_consumerResource Ids= org.eclipse.datatools.connectivity.oda.util.ResourceIdentifi ers @2692a74, reportEngine=org.eclipse.birt.report.engine.api.ReportEngine@3fd1ad2, Report_Data_Holder=com.xxx.xxx.reporting.dataholders.ds.DSDataHolder@24abddc, PARENT_CLASSLOADER=weblogic.utils.classloaders.ChangeAwareClassLoader@3e0e050 finder: weblogic.utils.classloaders.CodeGenClassFinder@3990622 annotation: cdx@cdx, Report_Request={Report_View_ID=-1, Report_UserSession=com.xxx.xxx.model.security.UserSession@2ad3132, Report_Module=[BaseRemoteObject] home: weblogic.ejb.container.internal.StatefulEJBHomeImpl@2df8ebc, Report_Session=weblogic.servlet.internal.session.MemorySessionData@328b389, Report_Datasheet=[BaseRemoteObject] home: weblogic.ejb.container.internal.StatefulEJBHomeImpl@2d9dc43, Report_Client=CDX_Web, Report_Type=1, Report_NODE_ID=900505913, Report_Creator=Li, Peng 101, Report_Language=de, Report_Format=pdf}, reportDesign=org.eclipse.birt.report.engine.api.impl.ReportRunnable@20c93ce, Report_Locale=de, PDF_RENDER_CONTEXT=org.eclipse.birt.report.engine.api.PDFRenderContext@383385a, Report_Render_Config=org.apache.commons.configuration.Hierar chicalConfiguration$1@2a11500, Report_Process_Config=org.apache.commons.configuration.Hiera rchicalConfiguration$1@2260f41}
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery PreparedScriptDSQueryss
FEINER: RETURN
FEINER: PreparedScriptDSQuery starts up.
19.11.2010 09:53:24 org.eclipse.birt.data.engine.impl.DataEngineImpl prepare
FEIN: Finished preparing query.
FEINER: RETURN
19.11.2010 09:53:25 org.eclipse.birt.data.engine.impl.ExprManagerUtil ExprManagerUtil
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@264e794
FEINER: RETURN
19.11.2010 09:53:25 org.eclipse.birt.data.engine.script.ScriptEvalUtil evaluateJSExpr
FEINER: ENTRY evaluateJSExpr() scriptText=new Date(), source=null, lineNo=0
19.11.2010 09:53:25 org.eclipse.birt.data.engine.impl.PreparedDummyQuery PreparedDummyQuery
FEINER: ENTRY org.eclipse.birt.data.engine.api.querydefn.SubqueryDefinitio n @25daea1org.eclipse.birt.data.engine.impl.DataEngineSession@249f703
19.11.2010 09:53:25 org.eclipse.birt.data.engine.impl.GroupBindingColumn GroupBindingColumn
FEINER: ENTRY null 0 {ID=org.eclipse.birt.data.engine.api.querydefn.Binding@91b, CREATION_DATE=org.eclipse.birt.data.engine.api.querydefn.Binding@2ea6b50e}
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@26f3fe1
FEINER: RETURN
FEINER: ENTRY evaluateJSExpr() scriptText=params["ID"], source=null, lineNo=0
FEINER: ENTRY org.eclipse.birt.data.engine.api.querydefn.SubqueryDefinitio n @25e6914org.eclipse.birt.data.engine.impl.DataEngineSession@249f703
FEINER: ENTRY null 0 {USER=org.eclipse.birt.data.engine.api.querydefn.Binding@27e3cb, CREATION_DATE=org.eclipse.birt.data.engine.api.querydefn.Binding@2ea6b50e}
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@271ccc1
FEINER: RETURN
FEINER: ENTRY evaluateJSExpr() scriptText=params["USER"], source=null, lineNo=0
19.11.2010 09:53:26 org.eclipse.birt.report.engine.layout.pdf.font.FontMappingMa nagerFactory loadFontMappingConfig
INFO: load font config in bundleentry://59.fwk36689683/fontsConfig.xml cost 99ms
19.11.2010 09:53:26 org.eclipse.birt.report.engine.layout.pdf.font.FontMappingMa nagerFactory$2 run
INFO: register fonts in /usr/openwin/lib/locale/ja/X11/fonts/TT cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_13/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ru.ansi-1251/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_15/X11/fonts/TrueType cost:0ms
INFO: register fonts in d:/windows/fonts cost:3ms
19.11.2010 09:53:42 org.eclipse.birt.report.engine.layout.pdf.font.FontMappingMa nagerFactory$2 run
INFO: register fonts in C:/windows/fonts cost:16653ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/truetype cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ar/X11/fonts/TrueType cost:0ms
INFO: register fonts in e:/WINNT/fonts cost:0ms
INFO: register fonts in /var/lib/defoma/x-ttcidfont-conf.d/dirs/TrueType cost:0ms
INFO: register fonts in C:/WINNT/fonts cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_2/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/tt cost:1ms
INFO: register fonts in /usr/openwin/lib/locale/th_TH/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_8/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_7/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/TTF cost:0ms
INFO: register fonts in /usr/openwin/lib/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/truetype cost:0ms
INFO: register fonts in f:/WINNT/fonts cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ko.UTF-8/X11/fonts/TrueType cost:0ms
INFO: register fonts in g:/WINNT/fonts cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_5/X11/fonts/TrueType cost:0ms
INFO: register fonts in f:/windows/fonts cost:0ms
INFO: register fonts in d:/WINNT/fonts cost:3ms
INFO: register fonts in /usr/share/fonts/ko/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_TW/X11/fonts/TrueType cost:0ms
INFO: register fonts in e:/windows/fonts cost:0ms
INFO: register fonts in /usr/share/fonts/zh_TW/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/ja/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_CN.GB18030/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/default/TrueType cost:0ms
INFO: register fonts in /usr/X/lib/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/euro_fonts/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/hi_IN.UTF-8/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh.GBK/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/OTF cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/iso_8859_9/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/X11R6/lib/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_TW.BIG5/X11/fonts/TT cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/ko/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh_HK.BIG5HK/X11/fonts/TT cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/KOI8-R/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/openwin/lib/locale/zh/X11/fonts/TrueType cost:0ms
INFO: register fonts in /usr/share/fonts/zh_CN/TrueType cost:0ms
INFO: register fonts in g:/windows/fonts cost:0ms
19.11.2010 09:53:42 org.eclipse.birt.report.engine.layout.pdf.font.FontMappingMa nagerFactory loadFontMappingConfig
INFO: load font config in bundleentry://59.fwk36689683/fontsConfig_win32.xml cost 6ms
INFO: load font config in bundleentry://59.fwk36689683/fontsConfig_pdf.xml cost 3ms
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.DataSetRuntime DataSetRuntime
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@25798d4 null
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime ScriptDataSetRuntime
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime <init>
FEINER: ScriptDataSetRuntime starts up
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ParameterUtil ParameterUtil
FEINER: ENTRY null org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@255580eorg.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25e7f48 [object Object]
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.QueryExecutor QueryExecutor
FEINER: ENTRY [object Object] org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25e7f48 org.eclipse.birt.data.engine.impl.aggregation.AggregateTable @30bb4b8org.eclipse.birt.data.engine.impl.DataEngineSession@249f703
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.PreparedQuery doPrepare
FEINER: Start to prepare the execution.
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@25798d4 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@255ae5e
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY null org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@256027borg.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25e7f48 [object Object]
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: Finish preparing the execution.
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ServiceForQueryResults ServiceForQueryResults
FEINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineSession@249f703 [object Object] 2 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@30bb0d3org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@30bb0d3 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@255ae5eorg.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25e7f48org.eclipse.birt.data.engine.impl.ExprManager@30bb4c8
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.QueryResults QueryResults
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ServiceForQueryResults@25832c9
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ExprManagerUtil ExprManagerUtil
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@30bb4c8
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.QueryExecutor execute
FEINER: Start to execute
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ExecutorHelper ExecutorHelper
FEINER: ENTRY null
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper populateData
FEIN: MemoryCache is used
FEIN: Time consumed by cache is: 0 second
19.11.2010 09:53:43 org.eclipse.birt.data.engine.expression.ColumnReferenceExpre ssion ColumnReferenceExpression
FEINER: ENTRY COMPANY
FEINER: RETURN
FEINER: ENTRY LOCATION
FEINER: RETURN
FEINER: ENTRY SUPPLIER_NUMBER
FEINER: RETURN
FEINER: ENTRY CONTACT_PERSON
FEINER: RETURN
FEINER: ENTRY CONTACT_TEL
FEINER: RETURN
FEINER: ENTRY CONTACT_MAIL
FEINER: RETURN
FEINER: ENTRY STREET
FEINER: RETURN
FEINER: ENTRY CONTACT_FAX
FEINER: RETURN
FEINER: ENTRY DUNS_NUMBER
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: Finish executing
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ResultIterator ResultIterator
FEINER: ENTRY org.eclipse.birt.data.engine.impl.QueryResults$ResultService@2498693 org.eclipse.birt.data.engine.executor.transform.CachedResult Set @258cb07 [object Object]
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.BindingColumnsEvalUtil BindingColumnsEvalUtil
FEINER: ENTRY org.eclipse.birt.data.engine.executor.transform.CachedResult Set @258cb07 [object Object] org.eclipse.birt.data.engine.impl.ResultIterator$RDSaveHelper@249a331 [org.eclipse.birt.data.engine.impl.GroupBindingColumn@30bc4c8] {}
FEINER: RETURN
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.QueryResults getResultIterator
FEIN: finished
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ResultIterator getValue
FEINER: get of value binding column: COMPANY
FEINER: get of value binding column: DUNS_NUMBER
FEINER: get of value binding column: STREET
FEINER: get of value binding column: LOCATION
FEINER: get of value binding column: SUPPLIER_NUMBER
FEINER: get of value binding column: CONTACT_PERSON
FEINER: get of value binding column: CONTACT_TEL
FEINER: get of value binding column: CONTACT_FAX
FEINER: get of value binding column: CONTACT_MAIL
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.ResultIterator close
FEIN: a ResultIterator is closed
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.QueryExecutor close
FEINER: executor closed
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.QueryResults close
FEIN: QueryResults is closed
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@259457f null
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY null org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@277269corg.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25ee370 [object Object]
FEINER: RETURN
FEINER: ENTRY [object Object] org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25ee370 org.eclipse.birt.data.engine.impl.aggregation.AggregateTable @30bb5d7org.eclipse.birt.data.engine.impl.DataEngineSession@249f703
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@259457f org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@2774737
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY null org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@27766d8org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25ee370 [object Object]
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineSession@249f703 [object Object] 2 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@30bb0fcorg.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@30bb0fc org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@2774737org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25ee370org.eclipse.birt.data.engine.impl.ExprManager@30bb5e7
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ServiceForQueryResults@2708ee9
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@30bb5e7
FEINER: RETURN
FEINER: ENTRY null
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY DELIVERY_NUMBER
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY SAMPLEREPORT_DATE
FEINER: RETURN
FEINER: ENTRY DS_STATE
FEINER: RETURN
FEINER: ENTRY CHANGE_DATE
FEINER: RETURN
FEINER: ENTRY NODE_ID
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.expression.ComplexExpression ComplexExpression
FEINER: ENTRY
FEINER: RETURN
FEINER: ENTRY
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY SAMPLEREPORT_NUMBER
FEINER: RETURN
FEINER: ENTRY ORDER_NUMBER
FEINER: RETURN
FEINER: ENTRY ID
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY
FEINER: RETURN
FEINER: ENTRY
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY ID
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.QueryResults$ResultService@2702177 org.eclipse.birt.data.engine.executor.transform.CachedResult Set @272f694 [object Object]
FEINER: ENTRY org.eclipse.birt.data.engine.executor.transform.CachedResult Set @272f694 [object Object] org.eclipse.birt.data.engine.impl.ResultIterator$RDSaveHelper@270412f [org.eclipse.birt.data.engine.impl.GroupBindingColumn@30bc98e] {}
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.script.JSRowObject JSRowObject
FEINER: ENTRY
19.11.2010 09:53:43 org.eclipse.birt.data.engine.script.JSRowObject get
FEINER: RETURN
FEIN: finished
FEINER: get of value binding column: PART_NUMBER
FEINER: get of value binding column: PART_NAME
FEINER: get of value binding column: SAMPLEREPORT_NUMBER
FEINER: get of value binding column: SAMPLEREPORT_DATE
FEINER: get of value binding column: ORDER_NUMBER
FEINER: get of value binding column: DELIVERY_NUMBER
FEINER: get of value binding column: ID_VERSION
FEINER: get of value binding column: NODE_ID
FEINER: get of value binding column: STATE_DATE
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@30bb2f3
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.data.engine.script.ScriptEvalUtil evaluateJSExpr
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.PreparedDummyQuery PreparedDummyQuery
FEINER: ENTRY org.eclipse.birt.data.engine.api.querydefn.SubqueryDefinitio n @25e70c5org.eclipse.birt.data.engine.impl.DataEngineSession@249f703
19.11.2010 09:53:43 org.eclipse.birt.data.engine.impl.GroupBindingColumn GroupBindingColumn
FEINER: RETURN
FEINER: RETURN
19.11.2010 09:53:43 org.eclipse.birt.dat]]>Peng 2010-11-19T09:16:09-00:00Re: Error: <unused> is not recognized! by using version 2.6.1
https://www.eclipse.org/forums/index.php/mv/msg/200497/640128/#msg_640128
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@27c913e
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.api.querydefn.SubqueryDefinitio n @25e794dorg.eclipse.birt.data.engine.impl.DataEngineSession@249f703
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@27dde9f
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@25287d8 null
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY null org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@27811acorg.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f0908 [object Object]
FEINER: RETURN
FEINER: ENTRY [object Object] org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f0908 org.eclipse.birt.data.engine.impl.aggregation.AggregateTable @30bb533org.eclipse.birt.data.engine.impl.DataEngineSession@249f703
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@25287d8 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@278416f
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY null org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@27869acorg.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f0908 [object Object]
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineSession@249f703 [object Object] 2 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@30bb0e4org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@30bb0e4 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@278416forg.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f0908org.eclipse.birt.data.engine.impl.ExprManager@30bb543
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ServiceForQueryResults@278fe1a
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@30bb543
FEINER: RETURN
FEINER: ENTRY null
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY ID
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY ID
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.QueryResults$ResultService@279b04b org.eclipse.birt.data.engine.executor.transform.CachedResult Set @2793011 [object Object]
FEINER: ENTRY org.eclipse.birt.data.engine.executor.transform.CachedResult Set @2793011 [object Object] org.eclipse.birt.data.engine.impl.ResultIterator$RDSaveHelper@279cb02 [org.eclipse.birt.data.engine.impl.GroupBindingColumn@30bc616] {}
FEINER: RETURN
FEINER: RETURN
FEIN: finished
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@253d837 null
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY null org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@2853fa0org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f1e04 [object Object]
FEINER: RETURN
FEINER: ENTRY [object Object] org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f1e04 org.eclipse.birt.data.engine.impl.aggregation.AggregateTable @30bb55corg.eclipse.birt.data.engine.impl.DataEngineSession@249f703
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ScriptDataSetAdapter@253d837 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@285a3f3
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY null org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime@285d079org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f1e04 [object Object]
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.DataEngineSession@249f703 [object Object] 2 org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@30bb0eborg.eclipse.birt.data.engine.impl.PreparedScriptDSQuery@30bb0eb org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$ScriptDSQueryExecutor@285a3f3org.eclipse.birt.data.engine.api.querydefn.QueryDefinition@25f1e04org.eclipse.birt.data.engine.impl.ExprManager@30bb56c
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ServiceForQueryResults@286d6af
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.ExprManager@30bb56c
FEINER: RETURN
FEINER: ENTRY null
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY LEVEL
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY MASS
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY LEVEL
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY MASS
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: RETURN
FEINER: ENTRY org.eclipse.birt.data.engine.impl.QueryResults$ResultService@288d136 org.eclipse.birt.data.engine.executor.transform.CachedResult Set @2878c63 [object Object]
FEINER: ENTRY org.eclipse.birt.data.engine.executor.transform.CachedResult Set @2878c63 [object Object] org.eclipse.birt.data.engine.impl.ResultIterator$RDSaveHelper@2899467 [org.eclipse.birt.data.engine.impl.GroupBindingColumn@30bc63d] {}
FEINER: RETURN
FEINER: RETURN
FEIN: finished
FEINER: get of value binding column: LEVEL
FEINER: get of value binding column: PART_NAME_IMAGE
FEINER: get of value binding column: PART_NUMBER_IMAGE
FEINER: get of value binding column: QUANTITY
FEINER: get of value binding column: MASS
FEINER: get of value binding column: PORTION
FEINER: get of value binding column: PORTION_INTERVAL
FEINER: get of value binding column: CLASS_IMAGE
FEINER: get of value binding column: CLASS_NAME
FEINER: get of value binding column: APPLICATION_IMAGE
FEINER: get of value binding column: APPLICATION_NAME_ID
FEINER: ge]]>Peng 2010-11-19T09:18:37-00:00Re: Error: <unused> is not recognized! by using version 2.6.1
https://www.eclipse.org/forums/index.php/mv/msg/200497/640129/#msg_640129
19.11.2010 09:53:44 DataEngineImpl shutdown
FEINER: ENTRY
19.11.2010 09:53:44 org.eclipse.birt.data.engine.impl.DataEngineImpl shutdown
FEIN: Data engine shuts down
FEINER: RETURN]]>Peng 2010-11-19T09:22:30-00:00Re: Error: <unused> is not recognized! by using version 2.6.1
https://www.eclipse.org/forums/index.php/mv/msg/200497/640213/#msg_640213
Run the report with the preview tab and then select the xml view and
look for any error indications.
Jason
On 11/19/2010 4:22 AM, Peng wrote:
> part4 :
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> getValue
> FEINER: executor closed 19.11.2010 09:53:43
> FEINER: ENTRY
> shutdown
> shutdown
> FEINER: RETURN]]>Jason Weathersby2010-11-19T15:35:14-00:00Re: Error: <unused> is not recognized! by using version 2.6.1
https://www.eclipse.org/forums/index.php/mv/msg/200497/640467/#msg_640467
there are the shown messages in the xml view:
Multiple annotations found at this line:
- org.eclipse.birt.report.engine.api.EngineException: Unhandled exception when executing script. at org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.addException(ScriptExecutor.java:162) at
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.addException(ScriptExecutor.java:147) at org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:9 9) at
org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.open( ScriptDataSetRuntime.java:80) at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor$CustomDataSet.open(PreparedScriptDSQuery.j ava:247) at
org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :223) at org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:1094) at
org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:232) at org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:172) at
org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init >(QueryResultSet.java:98) at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery(DteDataEngine.java:168) at
org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:265) at org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1876) at
org.eclipse.birt.report.engine.executor.QueryItemExecutor.ex ecuteQuery(QueryItemExecutor.java:80) at org.eclipse.birt.report.engine.executor.TableItemExecutor.ex ecute(TableItemExecutor.java:62) at
org.eclipse.birt.report.engine.internal.executor.dup.Suppres sDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor .java:43) at org.eclipse.birt.report.engine.internal.executor.wrap.Wrappe dReportItemExecutor.execute
(WrappedReportItemExecutor.java:46) at org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:34) at
org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:65) at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.la youtChildren(HTMLStackingLM.java:26) at
org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la yout(HTMLAbstractLM.java:140) at org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.resumeLayout(HTMLInlineStackingLM.java:111) at
org.eclipse.birt.report.engine.layout.html.HTMLInlineStackin gLM.layoutNodes(HTMLInlineStackingLM.java:160) at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.la youtChildren(HTMLStackingLM.java:26) at
org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la yout(HTMLAbstractLM.java:140) at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:70) at
org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.la youtChildren(HTMLStackingLM.java:26) at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layou tChildren(HTMLTableLM.java:132) at
org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout (HTMLPageLM.java:90) at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.layout(HTMLReportLayoutEngine.java:99) at
org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.doR un(RunAndRenderTask.java:180) at org.eclipse.birt.report.engine.api.impl.RunAndRenderTask.run (RunAndRenderTask.java:77) at
org.eclipse.birt.report.service.ReportEngineService.runAndRe nderReport(ReportEngineService.java:920) at org.eclipse.birt.report.service.BirtViewerReportService.runA ndRenderReport(BirtViewerReportService.java:973) at
org.eclipse.birt.report.service.actionhandler.BirtGetPageAll ActionHandler.__execute(BirtGetPageAllActionHandler.java:131 ) at org.eclipse.birt.report.service.actionhandler.AbstractBaseAc tionHandler.execute(AbstractBaseActionHandler.java:90) at
org.eclipse.birt.report.soapengine.processor.AbstractBaseDoc umentProcessor.__executeAction(AbstractBaseDocumentProcessor .java:47) at org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.executeAction
(AbstractBaseComponentProcessor.java:143) at org.eclipse.birt.report.soapengine.processor.BirtDocumentPro cessor.handleGetPageAll(BirtDocumentProcessor.java:183) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at
sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMe thodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at
org.eclipse.birt.report.soapengine.processor.AbstractBaseCom ponentProcessor.process(AbstractBaseComponentProcessor.java: 112) at org.eclipse.birt.report.soapengine.endpoint.BirtSoapBindingI mpl.getUpdatedObjects(BirtSoapBindingImpl.java:
66) at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method) at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAcce ssorImpl.java:39) at sun.reflect.DelegatingMethodAccessorImpl.invoke
(DelegatingMethodAccessorImpl.java:25) at java.lang.reflect.Method.invoke(Method.java:597) at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCP rovider.java:397) at org.apache.axis.providers.java.RPCProvider.processMessage
(RPCProvider.java:186) at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvi der.java:323) at org.apache.axis.strategies.InvocationStrategy.visit(Invocati onStrategy.java:32) at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118) at
org.apache.axis.SimpleChain.invoke(SimpleChain.java:83) at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService .java:454) at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281 ) at
org.apache.axis.transport.http.AxisServlet.doPost(AxisServle t.java:699) at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.doPost(BirtSoapMessageDispatcherServlet.java:265) at javax.servlet.http.HttpServlet.service(HttpServlet.java:
727) at org.apache.axis.transport.http.AxisServletBase.service(AxisS ervletBase.java:327) at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at org.eclipse.birt.report.servlet.BirtSoapMessageDispatcherSer vlet.service
(BirtSoapMessageDispatcherServlet.java:122) at org.eclipse.equinox.http.registry.internal.ServletManager$Se rvletWrapper.service(ServletManager.java:180) at org.eclipse.equinox.http.servlet.internal.ServletRegistratio n.service(ServletRegistration.java:
61) at org.eclipse.equinox.http.servlet.internal.ProxyServlet.proce ssAlias(ProxyServlet.java:126) at org.eclipse.equinox.http.servlet.internal.ProxyServlet.servi ce(ProxyServlet.java:60) at javax.servlet.http.HttpServlet.service(HttpServlet.java:820) at
org.eclipse.equinox.http.jetty.internal.HttpServerManager$In ternalHttpServiceServlet.service(HttpServerManager.java:318) at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder .java:511) at org.mortbay.jetty.servlet.ServletHandler.handle
(ServletHandler.java:390) at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandl er.java:182) at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandl er.java:765) at org.mortbay.jetty.handler.HandlerWrapper.handle
(HandlerWrapper.java:152) at org.mortbay.jetty.Server.handle(Server.java:326) at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnectio n.java:542) at org.mortbay.jetty.HttpConnection$RequestHandler.content(Http Connection.java:939)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:756) at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java: 212) at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java: 404) at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEn dPoint.java:409) at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThr eadPool.java:582) Caused by: java.lang.NullPointerException at
com.xxx.xxx.reporting.rptbuilders.ItemReportProductScriptedD ataSetEH.open(ItemReportProductScriptedDataSetEH.java:30) at org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:
96) ... 81 more
- org.eclipse.birt.report.engine.api.EngineException: There are errors evaluating script "reporting/dsType_substance.png": ReferenceError: "reporting" is not defined. (<inline>#1) at
org.eclipse.birt.report.engine.executor.ExecutionContext.add Exception(ExecutionContext.java:1195) at org.eclipse.birt.report.engine.executor.ExecutionContext.add Exception(ExecutionContext.java:1155) at
org.eclipse.birt.report.engine.executor.ReportItemExecutor.e valuateString(ReportItemExecutor.java:302) at org.eclipse.birt.report.engine.executor.ImageItemExecutor.ha ndleFileExpressionImage(ImageItemExecutor.java:279) at
org.eclipse.birt.report.engine.executor.ImageItemExecutor.ha ndleImage(ImageItemExecutor.java:148) at org.eclipse.birt.report.engine.executor.ImageItemExecutor.ex ecute(ImageItemExecutor.java:106) at
(WrappedReportItemExecutor.java:46) at org.eclipse.birt.report.engine.internal.executor.l18n.Locali zedReportItemExecutor.execute(LocalizedReportItemExecutor.ja va:34) at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.ex ecute
(HTMLAbstractLM.java:466) at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.ex ecute(HTMLAbstractLM.java:474) at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.ex ecute(HTMLAbstractLM.java:474) at
org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.ex ecute(HTMLAbstractLM.java:474) at org.eclipse.birt.report.engine.layout.html.HTMLListingBandLM .intializeHeaderContent(HTMLListingBandLM.java:98) at
org.eclipse.birt.report.engine.layout.html.HTMLListingBandLM .initialize(HTMLListingBandLM.java:50) at org.eclipse.birt.report.engine.layout.html.HTMLTableBandLM.i nitialize(HTMLTableBandLM.java:44) at
org.eclipse.birt.report.engine.layout.html.HTMLLayoutManager Factory.createLayoutManager(HTMLLayoutManagerFactory.java:40 ) at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutE ngine.createLayoutManager
(HTMLReportLayoutEngine.java:137) at org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:68) at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.la youtChildren
(HTMLStackingLM.java:26) at org.eclipse.birt.report.engine.layout.html.HTMLTableLM.layou tChildren(HTMLTableLM.java:132) at org.eclipse.birt.report.engine.layout.html.HTMLAbstractLM.la yout(HTMLAbstractLM.java:140) at
org.eclipse.birt.report.engine.layout.html.HTMLBlockStacking LM.layoutNodes(HTMLBlockStackingLM.java:70) at org.eclipse.birt.report.engine.layout.html.HTMLStackingLM.la youtChildren(HTMLStackingLM.java:26) at
org.mortbay.io.nio.SelectChannelEndPoint.run(SelectChannelEn dPoint.java:409) at org.mortbay.thread.QueuedThreadPool$PoolThread.run(QueuedThr eadPool.java:582) Caused by: org.eclipse.birt.core.exception.CoreException: There are errors
evaluating script "reporting/dsType_substance.png": ReferenceError: "reporting" is not defined. (<inline>#1) at org.eclipse.birt.report.engine.javascript.JavascriptEngine.e valuate(JavascriptEngine.java:287) at
org.eclipse.birt.core.script.ScriptContext.evaluate(ScriptCo ntext.java:154) at org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate(ExecutionContext.java:740) at org.eclipse.birt.report.engine.executor.ExecutionContext.eva luate
(ExecutionContext.java:669) at org.eclipse.birt.report.engine.executor.ReportItemExecutor.e valuateString(ReportItemExecutor.java:297) ... 87 more Caused by: org.mozilla.javascript.EcmaError: ReferenceError: "reporting" is not defined. (<inline>#1)
at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3654) at org.mozilla.javascript.ScriptRuntime.constructError(ScriptRu ntime.java:3632) at org.mozilla.javascript.ScriptRuntime.notFoundError(ScriptRun time.java:3717) at
org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRu ntime.java:1758) at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java :1697) at org.mozilla.javascript.gen.c14._c0(<inline>:1) at org.mozilla.javascript.gen.c14.call(<inline>)
at org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:398) at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:3065) at org.mozilla.javascript.gen.c14.call(<inline>) at org.mozilla.javascript.gen.c14.exec(<inline>)
at org.eclipse.birt.report.engine.javascript.JavascriptEngine.e valuate(JavascriptEngine.java:282) ... 91 more
- org.eclipse.birt.report.engine.api.EngineException: There are errors evaluating script "reporting/dsType_material.png": ReferenceError: "reporting" is not defined. (<inline>#1) at
evaluating script "reporting/dsType_material.png": ReferenceError: "reporting" is not defined. (<inline>#1) at org.eclipse.birt.report.engine.javascript.JavascriptEngine.e valuate(JavascriptEngine.java:287) at
org.mozilla.javascript.ScriptRuntime.nameOrFunction(ScriptRu ntime.java:1758) at org.mozilla.javascript.ScriptRuntime.name(ScriptRuntime.java :1697) at org.mozilla.javascript.gen.c15._c0(<inline>:1) at org.mozilla.javascript.gen.c15.call(<inline>)
at org.mozilla.javascript.ContextFactory.doTopCall(ContextFacto ry.java:398) at org.mozilla.javascript.ScriptRuntime.doTopCall(ScriptRuntime .java:3065) at org.mozilla.javascript.gen.c15.call(<inline>) at org.mozilla.javascript.gen.c15.exec(<inline>)
com.xxx.xxx.reporting.rptbuilders.ItemReportSupplierScripted DataSetEH.open(ItemReportSupplierScriptedDataSetEH.java:30) at org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:
96) ... 81 more
com.xxx.xxx.reporting.rptbuilders.ds.DSDetailScriptedDataSet EH.open(DSDetailScriptedDataSetEH.java:29) at org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleOpen(ScriptDataSetScriptExecutor.java:9 6) ... 81 more
org.eclipse.birt.report.engine.script.internal.ScriptExecuto r.addException(ScriptExecutor.java:147) at org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java: 150) at
org.eclipse.birt.data.engine.impl.ScriptDataSetRuntime.fetch (ScriptDataSetRuntime.java:103) at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor$CustomDataSet.fetch(PreparedScriptDSQuery. java:260) at
org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch (OdiAdapter.java:165) at org.eclipse.birt.data.engine.executor.cache.RowResultSet.nex t(RowResultSet.java:105) at org.eclipse.birt.data.engine.executor.cache.ExpandableRowRes ultSet.next
(ExpandableRowResultSet.java:63) at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .populateData(SmartCacheHelper.java:316) at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .initInstance(SmartCacheHelper.java:
285) at org.eclipse.birt.data.engine.executor.cache.SmartCacheHelper .getResultSetCache(SmartCacheHelper.java:246) at org.eclipse.birt.data.engine.executor.cache.SmartCache.<init >(SmartCache.java:72) at
org.eclipse.birt.data.engine.executor.transform.pass.PassUti l.populateOdiResultSet(PassUtil.java:110) at org.eclipse.birt.data.engine.executor.transform.pass.PassUti l.pass(PassUtil.java:62) at
org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.doSinglePass(PassManager.java:214) at org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.prepareDataSetResultSet(PassManager.java:97) at
org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.pass(PassManager.java:128) at org.eclipse.birt.data.engine.executor.transform.pass.PassMan ager.populateResultSet(PassManager.java:77) at
org.eclipse.birt.data.engine.executor.transform.ResultSetPop ulator.populateResultSet(ResultSetPopulator.java:198) at org.eclipse.birt.data.engine.executor.transform.CachedResult Set. <init>(CachedResultSet.java:192) at
org.eclipse.birt.data.engine.executor.CandidateQuery.execute (CandidateQuery.java:106) at org.eclipse.birt.data.engine.impl.PreparedScriptDSQuery$Scri ptDSQueryExecutor.executeOdiQuery(PreparedScriptDSQuery.java :226) at
org.eclipse.birt.data.engine.impl.QueryExecutor.execute(Quer yExecutor.java:1094) at org.eclipse.birt.data.engine.impl.ServiceForQueryResults.exe cuteQuery(ServiceForQueryResults.java:232) at
org.eclipse.birt.data.engine.impl.QueryResults.getResultIter ator(QueryResults.java:172) at org.eclipse.birt.report.engine.data.dte.QueryResultSet.<init >(QueryResultSet.java:98) at org.eclipse.birt.report.engine.data.dte.DteDataEngine.doExec uteQuery
(DteDataEngine.java:168) at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.e xecute(AbstractDataEngine.java:265) at org.eclipse.birt.report.engine.executor.ExecutionContext.exe cuteQuery(ExecutionContext.java:1876) at
com.xxx.xxx.reporting.rptbuilders.ds.DSDetailScriptedDataSet EH.fetch(DSDetailScriptedDataSetEH.java:35) at org.eclipse.birt.report.engine.script.internal.ScriptDataSet ScriptExecutor.handleFetch(ScriptDataSetScriptExecutor.java: 145) ... 97 more
i still can not see anything that may be related to <unused> tag.
Peng
]]>Peng 2010-11-22T08:50:18-00:00Re: Error: <unused> is not recognized! by using version 2.6.1
https://www.eclipse.org/forums/index.php/mv/msg/200497/640648/#msg_640648
Jason
On 11/22/2010 3:50 AM, Peng wrote:
> Because i am using scripted dataset event hanlder to create report at
> run time, so by your suggestion "run report with preview tab" there are
> alwasy some exceptions due to non-exsiting resources.
> der.java:323) at
> er.java:182) at
> Connection.java:939) at
> dPoint.java:409) at
> 96) ... 81 more
> der.java:323) at
> er.java:182) at
> dPoint.java:409) at
> ntext.java:154) at
> ntime.java:3654) at
> ntime.java:3632) at
> time.java:3717) at
> ntime.java:1758) at
> ry.java:398) at
> org.mozilla.javascript.gen.c14.exec(<inline>) at
> der.java:323) at
> er.java:182) at
> dPoint.java:409) at
> ntext.java:154) at
> ntime.java:3654) at
> ntime.java:3632) at
> time.java:3717) at
> ntime.java:1758) at
> ry.java:398) at
> org.mozilla.javascript.gen.c15.exec(<inline>) at
> der.java:323) at
> er.java:182) at
> dPoint.java:409) at
> 96) ... 81 more
> der.java:323) at
> er.java:182) at
> dPoint.java:409) at
> at org.eclipse.birt.data.engine.executor.cache.OdiAdapter.fetch
>]]>Jason Weathersby2010-11-22T16:47:36-00:00Re: Error: <unused> is not recognized! by using version 2.6.1
https://www.eclipse.org/forums/index.php/mv/msg/200497/640798/#msg_640798
Peng
]]>Peng 2010-11-23T08:43:26-00:00Re: Error: <unused> is not recognized! by using version 2.6.1
https://www.eclipse.org/forums/index.php/mv/msg/200497/640947/#msg_640947
Jason
On 11/23/2010 3:43 AM, Peng wrote:
> the dsType_substance.png is located under xxx.war/images/reporting/ and
> reporting related classes/design-files are under
> xxx.war/WEB-INF/lib/xxx.jar, wenn i run the report within server, the
> image is shown correct in the generated pdf report.
> Peng
>]]>Jason Weathersby2010-11-23T16:02:13-00:00
