Eclipse Community ForumsPDF compression or/and gzip
https://www.eclipse.org/forums/index.php/mv/msg/200471/639874/#msg_639874
I'm using the BIRT with my custom servlet.
1) Is there possibility to use the PDF compression? If it is possible, how to use it?
2) PDFRenderOption uses the servlet output stream:
options.setOutputStream(outputStream);
Is it possible to use GZIPOutputStream with BIRT if the browser accepts gzip? If it is possible, how to use it?
Mika]]>Mika Tapanainen2010-11-18T08:58:19-00:00Re: PDF compression or/and gzip
https://www.eclipse.org/forums/index.php/mv/msg/200471/640446/#msg_640446
Does anyone know the answers to my questions?
Mika]]>Mika Tapanainen2010-11-22T07:37:49-00:00Re: PDF compression or/and gzip
https://www.eclipse.org/forums/index.php/mv/msg/200471/640647/#msg_640647
The BIRT emitter is using iText which supplies a method to compress the
pdf (setFullCompression), but the emitter is already using this method.
Jason
On 11/22/2010 2:37 AM, Mika wrote:
> Hello,
> Mika]]>Jason Weathersby2010-11-22T16:43:57-00:00Re: PDF compression
https://www.eclipse.org/forums/index.php/mv/msg/200471/644935/#msg_644935
takes quite some time to process.
On 11/18/2010 3:58 AM, Mika wrote:
> Hello,
> Is there possibility to use the PDF compression? How to use it?
> Mika]]>Pinny Markowitz2010-12-14T20:36:41-00:00
