Eclipse Community ForumsIs SWTBot working on Win7 64Bit?
https://www.eclipse.org/forums/index.php/mv/msg/197420/629440/#msg_629440
Am I missing something or is SWTBot not supported on 64bit yet?
]]>Izaak van Niekerk2010-09-28T10:07:11-00:00Re: Is SWTBot working on Win7 64Bit?
https://www.eclipse.org/forums/index.php/mv/msg/197420/629503/#msg_629503
> I am running on a Windows 7 64Bit machine. Have installed the latest
> installations of SWTBot in copy of Eclipse 3.6 (Helios), but can not
> seem to get any of the features. I created a simple hello world test
> with the "@RunWith(SWTBotJunit4ClassRunner.class)" annotation etc, but
> when I right click on the class, the only "Run As" options I get are the
> JUnit one's, also nothing under the Run Configuration.
The usual answer is: SWTBot runs in any platform that SWT runs on. There
is nothing platform-specific in SWTBot that I'm aware of.
I don't really know what's going on for you. Seems like SWTBot is
installed correctly since you don't have any compilation problem. May it
be that the UI plugin didn't install? Or maybe you are using a target
platform and SWTBot is installed in it and not on your running Eclipse?
Could you take a look in Help -> About Eclipse -> Installation Details?
In the Installed Software tab, you should have SWTBot for
[GEF|Eclipse|SWT] Testing, and in the Plug-ins tab you should have a
couples of org.eclipse.swtbot entries and
org.eclipse.swtbot.eclipse.core (or ui, I think, depending on your
version) should be there.
*Because performance matters.*]]>Pascal G2010-09-28T13:57:46-00:00Re: Is SWTBot working on Win7 64Bit?
https://www.eclipse.org/forums/index.php/mv/msg/197420/629515/#msg_629515
I downloaded:
org.eclipse.swtbot-2.0.0.595-dev-e36.zip
org.eclipse.swtbot.eclipse..... zip
org.eclipse.swtbot.eclispe.text.junit4-......zip
extracted them and pointed the "Install Software" to this "local" location.
After installation ran, the following was added to the "Installed Software":
SWTBot for Eclipse Testing
SWTBot for SWT Testing
SWTBot JUnit 4.x Headless launchers for Eclipse
and in the Plug-ins:
org.eclipse.swtbot.eclipse.finder
org.eclipse.swtbot.eclipse.spy
org.eclipse.swtbot.go
org.eclipse.swtbot.eclipse.junit4...
org.eclipse.swtbot.junit4_x
org.eclipse.swtbot.swt.finder
But still not able to see the SWTBot features.]]>Izaak van Niekerk2010-09-28T14:43:25-00:00Re: Is SWTBot working on Win7 64Bit?
https://www.eclipse.org/forums/index.php/mv/msg/197420/629992/#msg_629992
Tim S2010-09-30T09:11:41-00:00Re: Is SWTBot working on Win7 64Bit?
https://www.eclipse.org/forums/index.php/mv/msg/197420/633521/#msg_633521
Is this issue still exists? I am currently running SWT files after my upgrade from windows xp to windows 7. Its giving me error as "Cannot load 32-bit SWT libraries on 64-bit JVM". Could you please help me on this?
Ullas]]>Ullas2010-10-18T10:25:23-00:00Re: Is SWTBot working on Win7 64Bit?
https://www.eclipse.org/forums/index.php/mv/msg/197420/633542/#msg_633542
Are you using Helios? ]]>Izaak van Niekerk2010-10-18T11:11:23-00:00Re: Is SWTBot working on Win7 64Bit?
https://www.eclipse.org/forums/index.php/mv/msg/197420/633600/#msg_633600
> Hi Izaak,
> Regards,
> Ullas
I'd take a chance and going to say you didn't install the proper SWT
(Eclipse) version. If you are running in a 64-bit environment, make sure
to download the Eclipse version for 64-bit[1].
*Because performance matters.*]]>Pascal G2010-10-18T13:51:11-00:00Re: Is SWTBot working on Win7 64Bit?
https://www.eclipse.org/forums/index.php/mv/msg/197420/633966/#msg_633966
Ullas2010-10-20T06:06:38-00:00
