Eclipse Community ForumsMatch values instance name - component name
https://www.eclipse.org/forums/index.php/mv/msg/193993/617021/#msg_617021
Users of VE in an zero-code application, drop custom components from the
palette to design windows which extends from JPanel. The current problem
they have is described below:
After adding the components to a Panel, they want to rename the beans by
clicking in "Rename Field" on the pop-up menu. Due to application
architecture, the name of the component must match with the property
"field name" and I have no idea how to develop it. I assume that i should
extends VE functionality... or maybe changing BeanInfo's class is enough???
Every time they change field name property, the name has to change as
well. Since field name is not a bean info property, i ask for help what's
the better way to solve it.
