Eclipse Community ForumsDataShareRMI
https://www.eclipse.org/forums/index.php/mv/msg/191945/609273/#msg_609273
I have some problems datashare.rmi plugin which seems to lack some
components (JoinException, Participant - is it ui.views Participant ?) ...]]>Pierre-Henry Perret2006-11-23T22:59:46-00:00Re: DataShareRMI
https://www.eclipse.org/forums/index.php/mv/msg/191945/609275/#msg_609275
I think without a lot of objection (from Peter and/or others) we should
probably deprecate datashare.rmi...as it was an early effort at
datashare which I think has been replaced by org.eclipse.ecf.datashare.
If others have other view please say so, as with 0.9.3 API refactoring
it's probably not going to make sense to maintain everything going forward.
Scott
Pierre-Henry Perret wrote:
> Scott,
>]]>Scott Lewis2006-11-23T23:36:07-00:00Re: DataShareRMI
https://www.eclipse.org/forums/index.php/mv/msg/191945/609276/#msg_609276
Scott Lewis wrote:
> Hi Pierre,
With regards to "deprecation", how do we want to deal with those CVS
modules? Leave them in CVS or move them in the attic or have webmaster
delete them (are those two the same thing?)? I guess if we leave them in
we should probably leave a note in the root project folder.
On the other hand, there is of course the maintenance issue that Scott
points out. I think in the case of org.eclipse.ecf.fileshare it should
probably be deleted/removed outright. But for datashare.rmi maybe it can
be left there (with a note or something on the website) in case someone
else wants to pick it up and maintain it in the future?
